Topic: Columns UI (Read 4620031 times) previous topic - next topic
Columns UI
Reply #4300
Actually, %_playlist_number%, which was in 0.8.x, still works.
%playlist_number%, which I remember turning up with 0.9, is what no longer works.
Columns UI
Reply #4301
Columns UI 0.3 beta 2 preview 5 released. See changelog for details.
For best performance when using artwork:
-Do not use wildcards.
-If you are not using it, disable the use of the foobar2000 artwork reader.
You will need to edit your artwork source scripts to not specify a file extension after upgrading.
Please report any issues encountered here.
Columns UI
Reply #4302
Nice.
Is any of the ways of looking for artwork (relative paths colums-style or foobar's built in reader) better than the other is some way?
(speed/memory-wise)
Columns UI
Reply #4303
Hello Musicmusic,
would you mind making the Filter Panels last selections available across sessions?
Any scripting help?
Lets say a music file is in directory "hello\". I have my artwork either as:
..\hello\ front/back/cover.jpg
OR
..\hello\covers\ front/back/cover.jpg
OR
..\hello\..\covers\ front/back/cover.jpg
Can anybody help me expressing that in the columns ui preferences?
TY, Lodl
Columns UI
Reply #4304
Meant to mention this before but it seems that the artwork column doesn't display a cover for albums that have illegal file name characters in the album name. I am using a central repository for my covers; there is no problem if the artwork is in the same folder as the music files. The path I'm using is
C:\Documents and Settings\ray\My Documents\My Music\Album Art\%album artist%\%album%\folder
Behaviour is the same whether or not the built-in artwork reader is used or not. The album art panel seems to display these covers ok.
Thanks a lot for all the work you have put into this component. It really has gone from strength to strength. Very much appreciated.
Columns UI
Reply #4305
Nice.
(speed/memory-wise)
Generally, speed-wise the Columns UI method will be faster, but you lose support for embedded art that way. First it tries the Columns UI method, and falls back onto the foobar2000 method if enabled. So it's best to try and use one or the other rather than both; I'm not sure if there is a proper way to restrict the foobar2000 method to embedded art only.
Memory-wise there is no practical difference.
Hello Musicmusic,
Lodl
It's maybe possible, I'll note it.
You need to use $replace - e.g. $replace(%album%,:,,?,,*,.). This way, you can use the same replacements you used when naming the files.
Columns UI
Reply #4306
Thanks for the update. I haven't got time to check my system time field issue yet, but I noticed a glitch:
This happens some times, if you don't release the mouse button after resizing.
EDIT: Forgot to mention, if you do something that refreshes the playlist view then it's ok after that.
Columns UI
Reply #4307
Ah, I know the problem, I'll fix it for next build, thanks for the report.
[edit] should be OK in preview 6
Columns UI
Reply #4308
There was some bugs with relative artwork paths; these should be corrected in preview 7.
Any scripting help?
OR
OR
You can only have one source per artwork type currently, so you would only be able to use one of those. Although the foobar2000 reader should pick up the first, so you can misuse things a little and make the Columns UI one pick up one of the remaining ones. The strings for those last two (front cover) should be:
covers\front
..\covers\front
Columns UI
Reply #4309
Wow, so fast, thank you.
Artwork problem fixed.
System time field problem fixed.
But, it's still "Auto-sizing g_columns" when right clicking on artwork column header.
Columns UI
Reply #4310
covers\front
..\covers\front
OK I see your point, but I still have to choose between one of those remaining 2, correct?
When I change to another panel, away from the ng playlist and return back, NG playlist has scrolled up to top position, this is not nice
Columns UI
Reply #4311
Oh.. Yes.. I meant to leave that there..  We can call it an Easter egg (until it's fixed...)
Correct.
Sounds like you re not using the built-in tab stack. But anyway it should be fine in the latest version.
Can I lock CUI window size? I'm able to do it in DUI and I want to do it in my CUI too.
No you can't. How does one accidentally resize a window?
Then, would it be possible to have an option to disable expansion to minimum height, like it was in preview 2 ? For now I'm stuck with it because I have a bunch of single files (which don't have album art), and no album with album art and only 3 or 4 tracks. So I was very happy with preview 2 behaviour.
But, you get clipped artwork then. I think it should be nicer with the default no cover image in the latest version.
Columns UI
Reply #4312
The problem with NG playlist selecting the first track is fixed, thanks!
Are there any plans for allowing multiple artwork paths? Because otherwise I will have to re-organize my album art.
Columns UI
Reply #4313
Would it be possible to add an option to split Group line into several lines in NG playlit? Either by inserting some string ($char(10) for example) or automatically if Group line exceeds width of playlist.
Columns UI
Reply #4314
lwiczek, I know it's not what you want but I think you can make your group string sorter by making it into multilevel group strings.
Columns UI
Reply #4315
Thuan, thanks - that would be just fine if only empty groups wouldn't be displayed. (for the moment i've set grouping this way and it's quite ok  )
Columns UI
Reply #4316
Foo_ui_columns is awesome and more than that since NG Playlist was introduce.
I have still two request :
- Is it possible to have a mirror effect for the cover ?
- I think one great things will be to add a column for the rating where you can click in to change it. The rating must be store in the tag %rating% i think.
The second one is perhaps possible now, I don't know if it is currently possible. But if it is can you explain me how to do that please.
Keep working and impress us musicmusic
Columns UI
Reply #4317
Is it on the todo-list to add a combined play/pause-button? After removing Panels Ui I really miss this feature.
Columns UI
Reply #4318
I have: [Main menu item] Playback/Play or Pause.
You can choose your own actions for the buttons.
Columns UI
Reply #4319
^Yes, but the button image doesn't change depending on if a track is playing or is paused.
Columns UI
Reply #4320
I'm trying out columns ui and like it so far. However there are a couple of things I'd like to get confirmed.
1) Is it possible to add info such as total tracks/albums, total length etc. next to entries in Filter and Playlist switcher? This was possible in default ui and very handy imo.
2) Can I edit the style of NG playlist groups? Currently my group script looks like this:
$if2(%album artist%,%artist%) - '['[%date%] [%label%]']' [%album%] '['[%genre%]']'
I'd like to bold %artist% and %album% and align %genre% to right side of screen.
Columns UI
Reply #4321
Fixed plans don't seem to work with this component, there's just too many things I would like to implement. But yes despite what I may have said previously, I would like to implement this, but we'll see how things go.
I don't plan to change this at the moment.
I already looked up the technicalities of the implementation, so what remains is that I actually implement it..
I definitely agree, this is the kind of thing would like to implement in the long term. So this is definitely planned but I don't know when I will implement it.
Well, I left room in the backend for different image states, but it's not actually implemented. I am not planning to implement it at the moment.
1. You can add some info fields in the playlist switcher panel. See here. You can't currently in Filter Panel.
2. This is not possible.
Columns UI
Reply #4323
Is there a way to turn off displaying default cover if there isn't any? I'd like to have covers in my playlist, but don't want defaults...
Columns UI
Reply #4324
No way now AFAIK, you can use a fake pic as default cover with the same color as your playlist view background.
