Topic: Columns UI (Read 4615899 times) previous topic - next topic
Air KEN and 3 Guests are viewing this topic.
Columns UI
Reply #4150
in regards to the grouping, is it also possible to hide a groups line if the is no match on a particular level... eg not all my albums are tagged with disc numbers as to me there is no point for a single disc album to be marked 1/1 so in this case the grouping line is not required but. I put the fields surrounded by [] to see if that would work but it still shows the grouping line... not sure how hard that would be but that would really help things nicely///
I don't really want to mess with the grouping backend at the moment, it's complicated enough as it is. But after 0.3 final I'll take another look.
Is the source for the Album List or Album List Panel available?
It's not available I'm afraid. The 0.9.x version of Album List is closed source and hence so is the panel version.
Columns UI
Reply #4151
I'd like to make a suggestion.  It may be useful to insert a step between the two existing steps listed under "Installation" at your ColumnsUI page.  That being, download and install your chosen version of ColumnsUI.  I'm new to foobar2000 (real new) and I put the DLLs in the components directory and I thought I was done--I couldn't figure out why I couldn't select the ColumnsUI interface.  Took me a few minutes.  Might seem dumb, but thought I'd suggest it.
Columns UI
Reply #4152
Columns UI 0.3 beta 1 preview 5 released.
awesome thx MM, I read a while back you were thinking about a playlist switcher rewrite which was why I mentioned my commends. filesize will siffuce.. cheers.
I added both %filesize% (formatted already) and %filesize_raw% (bytes).
Columns UI
Reply #4153
wicked .. using the latest version now and very happy with the updates.. once again proving that columns ui is the only way to fly
Columns UI
Reply #4154
Would it be possible to have an option to have just one autosend playlist rather than 2 separate ones?
I personally find having two playlists rather cluttered.
Columns UI
Reply #4155
Oh, many thanks!
1. Is there a chance you additionally add "Show 'All' node" for filter panel (as mentioned before)?
2. The %filesize% reports too high values here. For one (auto)playlist it says 26.6 GB, but fb2k preferences tell the truth: 7,26 GB.
Columns UI
Reply #4156
Yes some settings around that are on the to-do..
Yes:
So I can add an option to hide the "All" node, but probably I will add the option to hide nodes with empty labels first.
The properties excludes duplicates - does that explain it? Hmm, might be something to do with chapters/cuesheets actually.
Columns UI
Reply #4157
%filesize% shows me "8498099". I thought it was supposed to be formatted?
%filesize_raw% shows me a question mark .
Would it be possible for you to add a variable that will give me the size of a selection output in bytes? Something like %filesize_sel% or so?
Columns UI
Reply #4158
Should be sorted now in preview 6, thanks for the report.
This is in the playlist switcher
I'm not sure where or what selection you are referring too, I will assume you mean globally and for the playlist selection. Global fields that change with the playlist selection aren't so good, and also the UI isn't the right place to implement such global fields anyway. If you just want to see the filesize of the selection, a pane in the status bar or a selection properties panel is a better idea.
Columns UI
Reply #4159
I always forget those details. But yes, globally and playlist track selection. For example, I select 14 tracks in the playlist, I right click on the selection and go to the properties. In the properties, there is an entry titled "Total Size" and provides you the total size of the selection in MB and bytes. This is the value I am interested in displaying in a track info panel.
http://img.photobucket.com/albums/v326/kei...epropdialog.jpg
Columns UI
Reply #4160
If you want it in the Track Info Panel, it is better implemented on that component's side. If you do it globally, every single title formatted using title formatting will need to be refreshed when you change the selection. This is suicide behaviour.
I understand that no one is developing that panel at the moment (as far as I know anyway), but it was at least originally open source.
Columns UI
Reply #4161
Ah okay . Thanks for your hard work anyways .
Columns UI
Reply #4162
Hi musicmusic.
Could you implement an option in the status bar to show the size of the selected tracks and an option the show the number of selected tracks.
I really appreciate your hard work on this masterpiece.
Columns UI
Reply #4163
Columns UI 0.3 beta 2 preview 1 released. This adds support for displaying artwork in NG Playlist. Right click on the header and select artwork to enable. Artwork source is the same as the built in artwork viewer. As a preview version, it's not entirely perfect yet. The main thing I am aware of is that if the group only has a few tracks the artwork will be clipped, probably it would be better if the group was taller instead to accommodate it.
Sorry, I forgot to release a final beta 1. You can consider preview 6 that.
Columns UI
Reply #4164
Woah! That looks awesome musicmusic . Thanks for the update . I've been using your classic Columns Playlist View since forever, but this artwork view in NG is sweet .
I have just one feature request that I am missing from Columns PLV that I can't seem to figure out in NG. The background of the "Now Playing" item I can't seem to change it's color.
Here is a screenshot of how it looks with the classic CUI Playlist View:
(notice the purple background; that is the currently playing item)
Here is a screenshot of how it looks in NG Playlist View:
(notice the brighter white text with a black background; that is how it looks in NG Playlist)
I am using global settings for everything, so shouldn't NG look just like Columns PLV?
Columns UI
Reply #4165
Thanks, look beautiful and simple to set up.
Agree.
Columns UI
Reply #4166
Looks great.
I agree about increasing the height of a group for artwork, too.
And some other way to enable covers display would be good. Now it obviously isn't going to work if column titles are hidden.
Columns UI
Reply #4167
can anyone post me a playlist grouiping string for NG Playlist that would detect single tracks, like in lazy's configuration (experience.mod.fcl by lazy, v1.7)
it would be lovelly.please
LAME 3.100.1 -V0
Columns UI
Reply #4168
musicmusic, thanks again for continuing your work with CUI.
What do you think about NG playlist album-art database (like in wmp11,itunes7), where cached images are stored in database and at the next start loaded instantly instead of caching them every time?
Columns UI
Reply #4169
Thank you all for feedback
At first sight I would agree with you. But I need yur .fcl to investigate further. The only possibility I am aware of is if you use the old format style or global string which NG Playlist doesn't support (this is very old though).
Agree.
Yes, it will require some internal changes but it seems like the best approach.
Of course you are right, this is just an oversight on my part. I'll add an option in prefs some place.
I'm not sure it will make so much difference, the artwork still has to be read from disk (I think this is more related to the core anyway). Are you facing some problem with current behaviour?
Columns UI
Reply #4170
Sorry to hijack this. Well in my case, I think having album arts appear after awhile is a little inconvenience. So anyway around it and still keeping a fast scrolling speed is welcomed.
Columns UI
Reply #4171
Is this just when you do lots of scrolling? This creates a backlog of artwork to be read, I can change it so it processes the most recent request first, instead of the oldest.
The other method is to not load artwork on demand, rather just load it all in the background, but I'd rather try the above first.
I'm not sure how fast the foobar2000 artwork reader is, my artwork is stored in single dir/set up in Columns UI prefs which bypasses the foobar2000 reader (undoubtedly this is faster since it is only checking a single path and not searching for files or checking for embedded artwork).
Columns UI
Reply #4172
No, it won't make much difference, images are loaded instantly, no problems here. My mentioned method is slightly better, because hdd head doesn't need to jump to the beginning or to the end (according to the location of image) of disk to read the data. Reading images from one place reduces disk time/noise... and i think its more noticeable when you have ~80gb of mp3s, as in my case . I think thats the reason, why this feature is implemented in itunes and wmp.
Columns UI
Reply #4173
A bug in new NGPlaylist inline metadata editing
About artwork problem, yes it happens when I do a lot of scrolling. I'm trying to make my config simpler by using your component artwork in NGPlaylist instead of using graphical browser as I used to. And yes my artworks are put in the same folder as my music files which are about 90GB. So running around reading it does make noise from my HD. Anyway to improve it is welcomed.
Columns UI
Reply #4174
Wow, the NG playlist is awesome!  Lots of potential here.  I don't suppose you could add a little more control over its appearance via title-formatting or options?  Like, the ability to center the group title text over a particular column, ability to use a background color or something instead of the horizontal line, and being able to choose which column the album art goes in?
For example, having a narrow playlist numbering column first, then a wide column for the album name / artist info and album art thumbnail, then another narrow column for track-number, etc.  For example, this is what my regular columns UI looks like - it would be great if I could maintain this overall look while adding the benefits of grouping / album art thumbnails.
