Topic: Columns UI (Read 4620053 times) previous topic - next topic
Columns UI
Reply #3200
The bug I had with the video is reproduceable, I have already made it three times with 2 other videos showing that problem and the complete build and layout, do you want me to upload them ?
edit: I was wrong
Columns UI
Reply #3201
I have another question, is it possible to have tabs or something similar in the Album panel? I want to have a seperate album list for lossless albums and lossy albums/
Thanks in advance
Are you talking about Album List?
You can sort your albums inside Album List. Add a new view with this code:
$info(encoding)|%artist%|%album%|%tracknumber%. %title%
It's not exatly the thing you wanted, but it's kinda close
Thanks for your reply, I do mean the album list, can you tell me where I place that code so I can try it?
Thanks agian
Columns UI
Reply #3202
musicmusic. Is it possible that you could add margins (2px, left & right) to the volume and progressbar. If they are placed next to a border the slider get too close at the start and at the end. Currently I've solved the problem by adding an empty horizontal splitter to the right. I should probably have one on the left also but I feel it's less important.
Columns UI
Reply #3203
@musicmusic, my post got somehow lost, so i'm reposting it ... i would really like this implemented.
musicmusic, could you add special button command which would toggle autohide status for its parent splitter.
something like 'pin' in some guis. it would be nice if it could use some temporary autohide status, i.e. override autohide status for nearest parent with autohide actually checked (ignoring parents with autohide not set).
I see what you mean sort of. It would be sort of possible to have a similar command in buttons toolbar when I add "dependent layouts" feature.
weird resizing problem: look at the video:
http://eolindel.free.fr/images/bug.avi (3Mo)
Can you upload the foobar2000.cfg file that does that? Can you describe briefly what exactly you are seeing as well?
two crashes by the way, but i don't know where it come from:
It looks related to foo_uie_albumart.
I'll take a look at it.
Columns UI
Reply #3204
One 'hack' that you can use to get around the margins thing is to add a 2-pixel-wide trackinfo panel with the colours set to match your window. :shrug:
Columns UI
Reply #3205
when I try to resize the album art, clicking makes the album art to become smaller and smaller with a dark grey background even if I go on the right with my mouse, and when the album art is too small, it takes the whole space (huge black background filling the whole foobar window). And then when I go to my layout, several panels are "Hidden" while they should not, and even when I uncheck hidden, they do not appear again, the album art always take the whole space and I must restart a new layout
http://eolindel.free.fr/images/foobar/foobar2000.cfg
If you need other .cfg when the album art does not take yet the whole space, just tell me
Columns UI
Reply #3206
BTW, since I'm currently developing foo_uie_albumart, I'll take a look at this bug, too.  (though my knowledge of the ui_extension sdk is limited, so I'm not sure how much I'll actually be able to diagnose)
Also, what version of Windows are you using?
Columns UI
Reply #3207
Not sure if this is doable, but I've been looking for a different default action when playing a file. Basically, when I start playing a file, I would like the current playlist to be sent to replace a "Queue" playlist. This would basically mimic the fuctionality in mediamonkey which I really like because it automatically stores the current playlist so it is not replaced by browsing the library, searching, etc. and lets you easily edit the queued songs. Obviously, this would not be the default behavior, though, and would only be an option.
Columns UI
Reply #3208
Feature Request:
This is purely for the looks. It would be cool if it was possible to make the components have the toolbar look. Like in the image below... dotted gripper and gradient background (this is different depending on the theme). This is only possible at the top in the menu toolbar currently.
Columns UI
Reply #3209
musicmusic, i have a feature request . i was thinking - it would be nice not only show / hide columns according to playlist's name. i would like to be able to switch between views (i.e. different sets of enabled / disabled columns) for example from dropdown list. i would use 'views' like album mode, single mode, detailed mode etc.
what do you (and others) think?
Columns UI
Reply #3210
Really good idea!
Columns UI
Reply #3211
Concerning showing and hiding splitters I have a suggestion (I previously suggested). How about adding the possibility to add a shortcut to show/hide elements,splitters of the layout?
I find it very hard to target the toggle area. It's so small, that I most of the time have some "resize-arrows" shown..
Columns UI
Reply #3212
Feature request: "Lock this playlist view to current playlist."
Example of usage (read: the first thing I would do):
Add two instances of the playlist view panel, lock one to the playlist containing the enqueued tracks. Switching to another playlist in the playlist switcher now only affects the "main" playlist view, and not this locked one.
If achievable, this would eliminate the "need" for a dedicated foo_uie_queueviewer. Paired with autoplaylists, users could have panels showing dynamic lists of e.g. their current "Top 20", alongside their actual playlist.
Columns UI
Reply #3213
I didn't quite understand everything you described, but have you checked the "Enqueue incoming files..." and "Always send to playlist..." options under "Preferences -> General"?
Columns UI
Reply #3214
Could someone please tell me how to filter columns based on genre. I want "ensemble" & "subtitle" columns to display only when genre = classical or chamber if possible.
Thanks in advance.
Columns UI
Reply #3215
That's only for adding files from the commandline I think. If anyone has tried mediamonkey, you'll understand what I want. This would probably require a completely new component, though. It's really pretty simple. It would just need to make the current playlist replace the queue when anything in it is played.
Columns UI
Reply #3217
that would be nice, but as it is now, the core and columns_ui doesn't really support multiple playlist's views (plus you have playing and active playlist), things could get really nasty. not to mention that you can't have separate configuration for the other view (though you could enable / disable columns based on the queue playlist's name).
Columns UI
Reply #3218
Actually, I really wasn't even looking for the multiple playlist views function. I really just thought the queue viewer could be a normal playlist that can be accessed through tabs, the list, etc.
Columns UI
Reply #3219
actually that's the case at the moment, though you can't make any changes to the playlist. what i would like to see is support for accessing queue information from the formatting (and indicating it in the playlist view).
Columns UI
Reply #3220
I don't know the current limits of the core itself and UI Columns, regarding playlists. You're right about the problem with no separate config for each view, and you point out the solution I had in mind. But, I do realize that this would most likely lead to requests for separate configs.
After thinking about it, maybe this approach isn't the right one. Maybe it would be better having a multi purpose panel, with a more light weight formatting config. The idea, whether it's currently possible or not, in this way or that, is to have one single panel component with a large degree of flexibility, supporting multiple instances. Add them wherever you want, containing things you find useful (e.g. queue, history, top 20...).
Columns UI
Reply #3221
Exactly. As for the stuff that upNorth is talking about, multiple playlist views would be a nice feature to have, but it's not personally what I was looking for in my request. What I wanted, I think, is a lot simpler than it is being made out to be. A plugin (or feature built into columnsUI) would simply copy the current playlist and name it "Queue" as the default action when playing any file.
Columns UI
Reply #3222
Just to clarify. The idea/request i posted yesterday, had no relation to alphaex32's. It just happend to be posted on the same day.
Columns UI
Reply #3223
musicmusic please add ability to take previous and next item info in the list. something like this:
$prev(%tracknumber%) show previous item tracknumber
$next(%tracknumber%) ...
$if($prev(%tracknumber%), ... , ... )
etc...
it be usefull for many peoples 8)
p.s. sorry for my poor english 8D
Columns UI
Reply #3224
etc...
this has been discussed many times and it's probably not going to get implemented anytime soon. there's some idea of "grouping" by lyx, which may make it sometime later.
the problems are mostly because playlist items get processed in not exclusively sequential order etc ...
