Topic: Columns UI (Read 4610722 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Re: Columns UI
Reply #8025
I am experiencing new problems with sorting playlists with columns. It's slower than it was before, especially with larger playlists
Me too. With Columns UI 2.1.0 beta 2, sorting a 3000 item playlist takes 15-20 seconds. It was instantaneous before.
Re: Columns UI
Reply #8026
Thanks, reproduced. Investigating...
Re: Columns UI
Reply #8027
Should be fixed in beta 3.
Re: Columns UI
Reply #8028
The sorting issue is fixed for me in beta 3. Thank you.
Re: Columns UI
Reply #8029
Lately I've been noticing that the entries in Layout are always shifting around and never in the same place. This never happened to me before. How do I make it so this doesn't happen? I'm using the latest version.
Re: Columns UI
Reply #8030
Do you mean in the layout tree? Some screenshots (or a video if it's easily reproducible) would help.
Re: Columns UI
Reply #8031
Yeah, the layout tree. It started happening after switching from Panel Stack Splitter to JSplitter (SMP version). Fortunately, the way I have JSplitter currently setup it doesn't matter what order the panels are in. But I'd still like to be able to fix the issue.
I'll try and get screenshots or a video soon.
Re: Columns UI
Reply #8032
Doing some more investigating, I downloaded a JSplitter example that the author provides and I noticed that all the panel entries in the Layout tree have "Locked" selected. When I unlock them it behaves like my theme does, the panel entries randomly move around.
I was not aware that Locked behaved in this manor. I never used it for Panel Stack Splitter.  So is JSplitter the culprit here?
Here's a link to the example:
https://1drv.ms/u/s!Al_R2bXPNznkkDSqrui3QiUVmeue?e=10YhCe
Re: Columns UI
Reply #8033
Splitters manage their own children, and the layout tree queries splitters recursively and displays what they report. So, yes, I would assume what is being displayed is simply what is being reported by the splitter.
Locked is implemented by the splitter, so again the behaviour of it is down to the splitter.
Re: Columns UI
Reply #8034
Ah, I see. So it wasn't Columns UI that was keeping PSS in place like that. Good to know, thanks.
Re: Columns UI
Reply #8035
Foobar2000 v2.1 del 23.08.2023 crasha con Column UI Beta 3
Cardiacs
Re: Columns UI
Reply #8036
Could it be this?
Reply #638 https://hydrogenaud.io/index.php/topic,54933.msg1031780.html#msg1031780
i'm fine.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Re: Columns UI
Reply #8037
Risolto
Re: Columns UI
Reply #8038
i had searched on the board and Google but i can't find any reference about displaying "album art/covers" from online streaming radios that support it.
Any plan to add this option?
On Foobar default UI works.
Re: Columns UI
Reply #8039
in my theme , i explain in the ReadMe file how to add Album cover of Radio station stream
in preferences / display add the lines :
$if($strstr(%path%,'://'),C:\Radio\%album%.png)
$if($strstr(%path%,'://'),C:\Radio\%album%.jpg)
$if($strstr(%path%,'://'),C:\Radio\%album%.webp)
Create a folder to store the images of each radio station .
https://hydrogenaud.io/index.php/topic,124489.msg1031503.html#msg1031503.
Re: Columns UI
Reply #8040
.tags https://www.foobar2000.org/components/view/foo_tags it's the best solution to add the radio logo covers in a radio stream as seen in my skin:
https://www.youtube.com/@solomusica277
Re: Columns UI
Reply #8041
thanks but i don't want the radio logo. i need the Album cover, some radios streams the album cover of the song played
Re: Columns UI
Reply #8042
The built-in Artwork view panel is supposed to support this (added in version 1.7.0-beta.1). Which panel are you referring to?
Re: Columns UI
Reply #8043
This hxxps://www.youtube.com/watch?v=6NlG9KIk_hg  :D
Re: Columns UI
Reply #8044
Yes it works but i would like to have it in the grouping artwork...or i'm doing something wrong?
Re: Columns UI
Reply #8045
No, the playlist view doesn't support that. It would only make sense if it were the only track in the group. Are you sure the standard Default UI playlist view supports that? From my quick tests, the behaviour is the same as Columns UI.
Re: Columns UI
Reply #8046
No, it's the same, sorry i thought it was different.
Re: Columns UI
Reply #8047
Are there any means of preventing the checkered white border from appearing around a selected item after pressing any keyboard button?
Doesn't seem to happen on a portable DUI copy I tested this on and I do have the Windows setting unchecked in accessibility settings that causes this function on the desktop.
Re: Columns UI
Reply #8048
Which Windows setting are you referring to?
One option is to enable 'Use custom active frame' in Colours and fonts preferences, and change the colour to match the background. (You may need to use the latest 2.1.0 beta.)
Re: Columns UI
Reply #8049
Setting the active item frame to the background color will make the active item have a black border when selecting a group of track, and changing it to be the same color as the red I use for the selection causes a red outline on the active selection when clicking elsewhere. I just want no active item frame at all.
I'm pretty sure the Windows setting I mentioned doesn't exist, and I confused it with something else located in Control Panel\Ease of Access\Ease of Access Center\Make the keyboard easier to use.
