Topic: Columns UI (Read 4608484 times) previous topic - next topic
Columns UI
Reply #5925
what exactly is bugging you?
- you can disable windows aeropeek
- you can't change playback buttons on thumbnail preview from foobar preferences
- you can download additional component for windows 7 shell integration
Thank you for your reply.
This:
http://i49.tinypic.com/555u04.jpg
is bugging me. Sad to hear I can't remove it from foobar preferences. Is there any other way?
Please don't let it bother you. It seems to be standard behaviour.
http://img535.imageshack.us/img535/603/mpchc.jpg
Columns UI
Reply #5926
Is there a way to get last.fm info in the 'Item Details' box? I've tried using these:
%lastfm_bio%
%lastfm_similar_artist%
%lastfm_artist_playcount%
%lastfm_artist_listeners%
%lastfm_album_playcount%,
%lastfm_album_listeners%,
%lastfm_album_content%
but they don't seem to work. Any tips?
Columns UI
Reply #5927
@Svirre
Its not really Columns UI related
Go to Preferences --> Tools --> Biography Server --> Misc tab and enable "Provide titleformat fields"
Columns UI
Reply #5928
Lol, I guess not. Thanks for answering anyway!
Columns UI
Reply #5930
I'm using foo_ui_columns 0.3.8.4, and I have found changing only the case of a tag field's value will not refresh the changed tag field value that is displayed in the NG playlist group heading.
For Example: (1) %artist% = io echo -> (2) %artist% = Io Echo
Changing the value of %artist% from (1) to (2) will not change %artist% in NG playlist group heading, unless you refresh the playlist.
Columns UI
Reply #5931
Could you perhaps make the volume control on the status panel toggleable, like the one on the status bar?
I like using the volume control toolbar at the top, and the second volume control at the bottom just looks out of place then...
Seconded. See screenshot:
Columns UI
Reply #5932
Musicmusic, I reported it once, I still have problems with my Layout. The problem is, I hover over the caption of the Tab Stack, and it appears and disappears automatically. But since a couple of versions (or was it since Windows Vista? Same in Win7) it often does not automatically disappear any more. It does happen more often, I believe, since I use the new search field you introduced. In order to have the tab stack hidden again, I need to restart fb2k...
Unfortunately it's hard to track down, I still haven't found out when exactly it happens.
This is my basic layout:
Vertical Splitter
   Item Details
   Horizontal Splitter
   Tab Stack  <- "Hidden", "Auto hide"
      Vertical Splitter
      Vertical Splitter
      Explorer Tree
   Vertical Splitter
Inside the Tab stack, I've got some Filter panels also with the auto hide option. It's the same problem there.
Columns UI
Reply #5933
@musicmusic:
I love the new filter search bar, but this thing keeps buggin' me:
Columns UI
Reply #5934
Hi guys, I don't know if it has already been pointed out, but CUI isn't compatible with the latest version of foobar (or the problem is only on my end).
Columns UI
Reply #5935
The problem is only on your end.
CUI 0.3.8.4, f2k 1.0.1
Columns UI
Reply #5936
is it possible to make the filters headers editable as search? I used to know how to do it on preferences, but I can't seem to do it anymore. I don't even know what the fuck happened, as far as I remember, there wasn't an update on columns UI or foobar since.
like if I type 'emp' on the artist filter header, it would show up every artist containing emp on their name.
thanks in advance!
edit: so, I found out that I was using version 0.3.8.3, and to make search available for a filter I just needed to right-click the list and toggle search in the popup menu. but I thought I'd give the filter search feature a try, so I switched back to 0.3.8.4 and toggled it, but it doesn't do anything. I can type even a word that only one of my songs has on it, that it still keeps showing all songs on library.
I don't get the feature and there isn't documentation, as far as I know, cause if I click on filter in the documentation wiki, it just brings up a page containing the word 'complete'.
anyone could explain the filter search bar?
Columns UI
Reply #5938
0.3.8.5 released - contains improvements to the Filter search toolbar.
Columns UI
Reply #5939
  • Filter search will now function if no Filter panels are in the active layout
  • Added Clear button to Filter panel
  • Fixed Filter search misbehaviours when Filter precendence is set to “By field list above”.
  • Enter key in Filter search now displays results in Filter panel autosend playlist
  • Misc Filter search bug fixes
Enter works only if filters are visible in layout
Making clear button optional would save some toolbar space
Columns UI
Reply #5940
I got a problem to change toolbar buttons, when i try to replace a default button with a png, i got a blank space where the button is...anyone knows why?
Columns UI
Reply #5941
I've a couple of questions (CUI version 0.3.8.4):
- Is it possible to set a minimum height for panels? I mean like e.g. foo_uie_albumart and foo_uie_trackinfo had in options.
- I'm having the following issue with column headers: I'd like to add a "Starred" column with "Center" alignment, having the star symbol as both header and value; value is shown correctly but header text is not centered and is cut:
I tried with both Columns Playlist and NG Playlist.
If I resize the column, no matter the size the header text is never centered with the value (it's always a bit on the right).
EDIT: column size is 22.
Is there any way to fix this?
Thanks and regards,
Lorenzo
Columns UI
Reply #5942
Download the libpng and zib libraries file from musicmusic's Columns UI page, and place the files in your foobar2000 directory.
Columns UI
Reply #5943
If I change an album title from the Properties window to lowercase/uppercase, it is not instantly updated on the playlist using Columns UI. I have to switch to another playlist, and then back, and it's updated. This does not happen without Columns.
Can anyone else reproduce this, or is it just me?
Columns 0.3.8.5, foobar2000 v1.01.
Columns UI
Reply #5944
Although Columns UI provides a great deal of customizable elements I've been always bugged by the fact I was unable to alter the colours of 'Playback order' toolbar as no settings under 'Colours and fonts' subcategory seem to affect it. Moreover I noticed that the default UI's global colour settings seem propagate over every UI control available in such configuration (together with the equivalent 'Playback order' combo control) therefor I've been wondering how come this little issue had never been addressed before... :|
Also, I'd like to make a suggestion regarding the optional Console panel and the ability to customize it's colours (which is surprisingly missing) apart from the already available font change. The last tiny issue regarding the Console panel would be the newline character appended to the last line of the console log. I'm not familiar with the foobar API but would it be possible with the least efforts to avoid adding this blank line at the end?
The following screenshot illustrates all the above little annoyances:
I'm aware that what I'm asking for is something of very little importance and priority, nevertheless it would be much appreciated if any of the above could be looked into.
As to clarify -- I'm using the latest Columns UI 0.3.8.5 and the foo_uie_console 0.4.
Best regards,
r0641
Columns UI
Reply #5945
Well, I reproduced this on another machine running a different configuration so it indeed seems to be a bug.
Columns UI
Reply #5947
I dig it, now it's working, but I guess it's still a little slow, old search used to be quicker.
I thought that it would be because it was in a splitter with three filters, but even thought I put it in a separate vertical splitter with just one filter, it still searches all of them.
like this.
Columns UI
Reply #5948
My column UI just went very buggy today. It all started when I updated to 8.4.5 this afternoon. So I got back to 8.4.3. Didn't change anything. Finally put 8.4.5. For an unknown reason, it seems to have created one "Column UI" entry every time I swapped column ui's version. Here is a screen :
And that's to show how buggy it is.
Columns UI
Reply #5949
This thread starts to look like CUI appearance thread
Don't you posters know what thumbnail is, and why it exists?
