Topic: Columns UI (Read 4609686 times) previous topic - next topic
0 Members and 13 Guests are viewing this topic.
Columns UI
Reply #5475
OK, lots of colour codes would also contribute to it. It can flicker even in the old version, it just takes more to do it.
Anyway writing my own status bar control, or maybe replacing it with something else, would be the solution. I will have a think about it...
Columns UI
Reply #5476
I have the same flickering problem under Windows XP SP3, with a fairly standard script. The update interval also is 2 sec.
$if(%ispaused%,Paused,Playing) | %codec%[ %codec_profile%][$replace(%__tool%,LAME,'Lame ')] | %bitrate% kbps | %samplerate% Hz | $caps(%__mp3_stereo_mode%) | %playback_time%[ '('%length%')']$tab()[%replaygain_track_gain%][  %replaygain_album_gain%  ]
Columns UI
Reply #5477
Request for an option (cutting artwork in playlist) :
Now:
What I'd want:
workable ?
I'd like to second this question; if this could be introduced in Columns UI, then we would no longer need an update allowing only selected album art (for instance, for albums) to be displayed.
Columns UI
Reply #5480
Thanks, i'm blind 8-D
Columns UI
Reply #5481
Yeah, take that glasses off
Columns UI
Reply #5482
Do you also cut all your CD-cases if they don't fit on your shelf?
At least this should be an OPTION, not a default behavior!
Columns UI
Reply #5483
I don't think I ever suggested it should be default behaviour? Obviously I would prefer a full update allowing us to specify when album art is displayed, but in leu of this, the ability to crop (for when there are fewer than a specified number of items) would help many.
Here is my original problem, which I understand many people face when using Columns UI; I organise my music in the following fairly generic way:
Artist Folder     > Album A
                          > Album Track 1.mp3
                          > Album Track 2.mp3
                  > Album B
                          > Album Track 1.mp3
                          > Album Track 2.mp3
                  > Single 1.mp3
                  > Single 2.mp3
At the moment, I have grouping as:
$meta(ALBUM ARTIST)
$meta(ALBUM)
This arranges my music in the way that I want; that is, with each artist having their own group, under which are the singles, proceeded by the albums. My problem is thus: With the singles, there is a 'No Art' image and a line above them, as if they were another album. There is presently no way to get Columns UI to change the display from:
to...
The most any of us can have is a black 'No Art' image, but unless we're content to have tiny album covers, this leaves huge blank gaps where an artist may have only one song in the library. Also, it doesn't fix the problem of the additional (unwanted) horizontal line, signifying another 'group'.
Columns UI
Reply #5484
You can (for now at least), get rid of the white line with a $tab(). You can't get rid of the space the line occupies though.
Concerning the album art, you might want to try a 1 pixels high and as many pixels wide, as you specified as Artwork width, transparent png. I don't know if this would work though.
Columns UI
Reply #5485
Do you mean create a 1x1 transparent PNG for the No-Art image? I just tried that and had no luck. If you mean specify 1x1 as the artwork size, then that sort of defeats the object of this UI.
Also, how would I use the $tab() code? How would I insert that into this grouping?
$meta(ALBUM ARTIST)
$meta(ALBUM)
Columns UI
Reply #5486
Concerning the $tab code, you would write the following:
$if($meta_test(album),%album%,$tab())
I meant that you could create a transparent png of the width, that you specified as the artwork size and the height of 1px. I didn't test this though and thus have no idea if this will actually work.
Columns UI
Reply #5487
hello, first post
i have a simple scripting request that i cant for the life of me figure out. is there a way to make a single column that sorts by album, then disc number, then tracks on that album (for something like a trance compilation that may have multiple artists on it), but then also sorts the rest of a playlist by artist?
i think album artist is basically the way to solve my problem; i have the trance compilation tagged with a single album artist. what script would i put so that the compilation would appear in the proper order (discs & tracks) in line with my other music in a single playlist, where the rest of the music is tagged by artist only?
Columns UI
Reply #5488
Ah nice idea, though unfortunately I just tested it and Columns UI allots the space (for instance, of 100x100) regardless of the art size, which is then enlarged/reduced as necessary.
Columns UI
Reply #5489
Columns UI 0.3.7.9 released.
This should prevent the status bar from flickering
Console panel 0.4 released
This throttles updates to the panel when the console is being "spammed", and increases the maximum number of messages displayed to 200.
Columns UI
Reply #5490
musicmusic,
thank you very much for both of your updates.
With CUI v0.3.7.9 the flickering is completely gone (in spite of my intensive use of colour codes) and the status bar now shows its content absolutely smoothly!
And since it was me who asked for more entries in the Console panel I appreciate v4.0 very much.
Robertina.
Columns UI
Reply #5492
Sorry, i want to report another small problem i have (with Item details).
Under certain circumstances word wrapping doesn't work correctly.
Workaround: clicking "Word wrapping" twice, but doing some other actions with item details and problem reoccurs.
Columns UI
Reply #5493
Just put up 0.3.8.0 - should fix that issue.
Thanks for the report.
Columns UI
Reply #5494
Love this UI - except on startup it does not display the full playlist, if I just resize the window, it displays ok at that point - any suggestions?
Columns UI
Reply #5495
It sounds to me like you may have locked some panels in a wrong way. If they are locked, try unlocking them and see if it fixes the problem
Columns UI
Reply #5496
Nope no panels were locked.  Would seeing my FCL help?  Does this forum allow uploads?
Columns UI
Reply #5497
You can use the upload forum, also some screenshots would be good.
Columns UI
Reply #5498
@musicmusic, could you add special toolbar button that would display main menu items in popup menu. I'm talking about something like this:
Columns UI
Reply #5499
mixcherry,
how did you realize not to have foobar's main menu in your screenshot's layout?
I like your idea of having such a toolbar button, combined with the possibility to do without the main menu bar.
