Topic: Columns UI (Read 4618609 times) previous topic - next topic
Columns UI
Reply #5000
Well I have Logitech Setpoint on my computer and that's it. Thanks for pointing out the problem.
Columns UI
Reply #5001
problem at http://yuo.be/columns.php
no link to download columns ui
Music is my first love.
Columns UI
Reply #5002
Click on the version number, Melomane.
@musicmusic: I switched to autohotkey and lost some of my mouse functionalities but rendering is fine, now. So is it a bug in the OS or the way Setpoint enforce its global hook?
Columns UI
Reply #5003
I've just started using the NG playlist instead of the old one, but I can't figure out exactly how the grouping works. I understand how you let it decide when to group items, but is there a way to decide what group title is displayed?
I've tried the following two strings:
%directoryname%
This one groups correctly, but the title uses the directory name, which is not very useful for multi-disc releases, in which case the group title is "disc 1", "disc 2" etc. It also does not display the artist name anywhere.
I've also tried this one:
$if($stricmp(%album artist%,%artist%),%Artist%[: %album%],Various Artists[: %album%])
It correctly groups most normal albums and various artist albums and displays the album artist in the group title when there's only one artist on the release. It also displays the artist in the track title when the release is various artists. It fails when the album artist is the same as the track artist for some but not all tracks on the release, it then creates extra groups (example).
Is there any way to combine those two to get what I'm looking for? I just want the items to be grouped by directory and show the album artist in group title and if it's a various artists release, the different track artists in the track titles.
Columns UI
Reply #5004
You can't specify a separate title formatting for what to display in the group header. And yes, it's a feature that's requested often.
In your case, is there really a need to group by directory? Usually, grouping by %album artist% - %album% is sufficient, as long as you mark your various artists albums by "Various Artists" in the album artists field. (Also note that if the album artists field is missing, %album artist% is remapped to %artist% -- see here -- so that you don't really need the $stricmp() part in your grouping.)
Columns UI
Reply #5005
I would suspect that track 7 in that screenshot was missing ALBUM ARTIST=Various Artists, hence why it is separate. You may have other inconsistencies in your meta-tags as only some of your dates are truncated.
You may also be interested to know that the value %track artist% only exists if %album artist%!=%artist% and takes on the value of %artist%, it could simplify your code a bit.
Columns UI
Reply #5006
Thank you, that's exactly what I want. I hope that wasn't the default grouping string, because in that case I wasted a lot of your time because of my meandring through scripts. The reason I wanted to group by directory was simply to avoid the problems I had with the other string.
Columns UI
Reply #5007
@musicmusic : can we customize the foo_uie_console colors (font and background) ? I don't see Console in the colours tab.
Columns UI
Reply #5008
musicmusic can you look at this item details issue
Columns UI
Reply #5011
Great. It still has nothing to do with me.
Columns UI
Reply #5012
musicmusic, could you add possibility to set different columns for Columns Playlist and for NG Playlist? It would be useful if you use both Columns and NG. For example, there is no need to show %artist% or %album% in NG.
Columns UI
Reply #5013
Hello,
i have several soundtracks in a playlist with the album artist field containing "Various Artists", but the NG Playlist won't group the tracks correctly. What am i doing wrong? Am i missing something? Shouldn't soundtracks and samplers be grouped correctly by default?
Thanks in advance for any help.
Columns UI
Reply #5014
simple, hide the columns
Columns UI
Reply #5015
Hello,
Under "Preferences->Display->Columns UI->Playlist View" and then under the "Grouping" tab you can specify how everything is grouped in the NG playlist. Then you can set up multiple grouping schemes for individual playlists.
Columns UI
Reply #5017
BTW, Album Art in NGP needs a setting for having some vertical space, currently it's directly connected with the group row which is ugly sometimes.
I agree with this. I guess that at the moment there is no way to adjust this?
EDIT: Actually I found an ugly way to make this look a bit better. I changed the group title font into something that has a bit more vertical space under characters... Not pretty, but will do for now.
Columns UI
Reply #5018
Artwork doesn't support bmp.
There was simple trick in Trackinfo Panel:
text
text
text1text2
Does Item Details support something like that?
Columns UI
Reply #5019
Not SetPoint's fault (well I don't know why it needs a global hook, but that's a different question). I don't see any compelling reason that the OS is not at fault. I will try and check Windows 7 beta 1 64-bit sometime.
Not at the moment (beyond changing system settings).
There is something like a 'show when grouped' option planned for each column which should do what you need.
The Columns UI reader one does. I can't control what the foobar2000 reader does / doesn't do.
Not currently.
Columns UI
Reply #5020
if someone could help me with a NG Playlist grouping script, i'd appreciate it.
i would like it to group by Album Artist and Compilation tags when Album Artist tag is present. when it's not present, i want it to group by Artist and Album.
i've been trying for a while, and i just can't seem to figure it out. thanks.
Columns UI
Reply #5021
Quick example:
$if($meta(album artist),%album artist% $char(8226) %compilation%,%artist% $char(8226) %album%)
or:
%album artist% $char(8226) $if($meta(album artist),%compilation%,%album%)
Columns UI
Reply #5022
that works. thanks a lot.
Columns UI
Reply #5023
Yeah, i know. But what do i have to enter there to group compilations correctly? I have no clue.
Columns UI
Reply #5024
@musicmusic, thank you for the amazing Columns UI Filter option.
Have a suggestion to add features should you consider it viable.
Could we have option to discard duplicates in filter results?
Maybe, in Columns UI/filter, an area to enter %title%/%artist%/%album%/etc. to personalize the duplicates criteria.
After above query has been met, Columns UI Filter could allow the result to retain e.g. most rated, most played, higher bitrate, etc.
e.g., if five files have same %title% & %artist%, only one would be retained in filter results. This could be the one with highest bitrate, most played one, etc.
