I played around with artwork repository front path and came up with this long a** string.
$if($cwb_fileexists($replace(%path%,%filename_ext%,)cover.jpg),$replace(%path%,%filename_ext%,)cover.jpg,$if($cwb_fileexists($replace(%path%,%directoryname%'\'%filename_ext%,)cover.jpg),$replace(%path%,%directoryname%'\'%filename_ext%,)cover.jpg,$if($cwb_fileexists($replace(%path%,%filename_ext%,)cover Disc %disc%.jpg),$replace(%path%,%filename_ext%,)cover Disc %disc%.jpg,$if($cwb_fileexists($replace(%path%,%filename_ext%,)cover.png),$replace(%path%,%filename_ext%,)cover.png,$if($cwb_fileexists($replace(%path%,%directoryname%'\'%filename_ext%,)cover.png),$replace(%path%,%directoryname%'\'%filename_ext%,)cover.png,$if($cwb_fileexists($replace(%path%,%filename_ext%,)cover Disc %disc%.png),$replace(%path%,%filename_ext%,)cover Disc %disc%.png,$if($cwb_fileexists($replace(%path%,%filename_ext%,)cover.gif),$replace(%path%,%filename_ext%,)cover.gif,$if($cwb_fileexists($replace(%path%,%directoryname%'\'%filename_ext%,)cover.gif),$replace(%path%,%directoryname%'\'%filename_ext%,)cover.gif,$if($cwb_fileexists($replace(%path%,%filename_ext%,)cover Disc %disc%.gif),$replace(%path%,%filename_ext%,)cover Disc %disc%.gif,)))))))))
Well my covers are all in these searched places. After caching all of my album arts (actually I scrolled around a bunch of times), it does scroll impressively fast.
Will you implement wild cards support and multiple sources in the future so ppl like me don't have to deal with it with patched work like this?
Also I would like to have system minute and system second available after checking "Make date info available" in global tab.
