Topic: Columns UI (Read 4608810 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Columns UI
Reply #3775
suggestions added, nothing to over the top just a new 3d engine with a flight simulator option when you hit F7, no only joking  just a couple additions
Hehe, actually personally I wouldn't mind tagging directly from the filter panel, it would be pretty easy to locate and clear up bad metadata.
I think that is a better idea for sure, set it up if you got time and I look forward to testing it out
Columns UI
Reply #3776
0.2.1 alpha 3 released, some enhancements to the filter panel. Please give the auto-refresh a good trashing
Columns UI
Reply #3777
Holy crap! that  would be awesome!
b. Use stuff like %genre% instead of Genre? (i was trying to get a %date% %album% type field, but i just can't figure out how i'd put it in)
I don't really want to add title formatting, I don't feel it is necessary, it will impact performance and plus it will require too many hacks (on my side) to get multiple values per field working with it.
That makes sense... performance is priority no 1 . What about browsing by directory structure?  Suppose we have a path as follows:
Z:\Music\Classic Rock]\Led Zeppelin\[1969] Led Zeppelin\##- Title.mp3
It'd be awesome if we could access the directory marked in bold it using something like PATH(1) (where path(0) = root directory, etc) or something.
Actually any implementation of directory browsing would work for me .
Columns UI
Reply #3778
Sad, I love similar Facets functionality. Though I still hope that either there will be a way to use Default UI elements into Columns UI layout or new SDK will provide an easy way to implement similar functionality.
Anyway, I'm switching back to Columns UI. Great work musicmusic, thank you for the great UI.
upd: Hell yeah, Globals functionality is just what the doctor ordered
Sharing delusions since 1991.
Columns UI
Reply #3779
Thx musicmusic for the nice enhancements
Could you implement keyboard-A-Z-navigation in the filter-listview, e.g. pressing 'p' selects the first entry beginning with p.
edit: typo
Columns UI
Reply #3780
It's not so difficult for fb2k developers to do smomething like that. When foosion said:
It is always good to have some competition.
I think they already consider about it seriously.
By the way, great job and great character, musicmusic.
Columns UI
Reply #3781
Feature request. Globals usage in NG playlist grouping strings.
Columns UI
Reply #3782
Hi, I have a quick question: how to return selection borders in version 0.2+? they are shown when i press 'Ctrl' but disappear after foobar losts focus.
Here is screenshot if I'm being unclear:
Thanks in advance.
Columns UI
Reply #3783
It seems my quicksearch toolbar does not work with the latest version of column_ui, under 0.9.5. Am I wrong ?
Columns UI
Reply #3784
It works for me with foobar2000 0.9.5 beta 1, Columns UI 0.2.1 aplha 3 and Quicksearch toolbar 2.8l
Columns UI
Reply #3785
ok ... , i've probably missed something - thanks.
Columns UI
Reply #3786
Works for me too. I only wish the search window would close when I press enter.
Columns UI
Reply #3787
Another feature request. Alignment into grouping strings. I.e. I want to place green highlight onto the red highlight.
Columns UI
Reply #3788
medialibrary auto update is working really well...
another request for ngplaylist is to select an album by the group name, so I dont have to highlight every song, I just click on the group name..
also in ng playlist is I select a song, hold shift and click the end of an album it does not select the whole album either it just highlights the bottom song... to me this is standard windows behavior that should be implemented... what do you think?
tagging from filter is also very sweet saves me lots of time and makes tagging a breeze, especially for finding badly tagged stuff... what are the future plans... so for filter what about inline tagging in the filter window itself... could be an interesting idea...
Columns UI
Reply #3789
Two Three more feature request if I may
1. The ability to put a button on the toolbar which envokes a drop down menu, like the ones already available for navigating backwards and forwards through tracks.
But with the ability to put the other button commands in the menu. This would allow for a less cluttered toolbar while also having a lot of functions available fast and it would allow to group related functions.
2. Having an entry in the View -> Layout menu to switch back to the previously chosen layout.
3. Overriding the font-type for specific columns. For instance I would like to use Wingdings in my ratings column so I can use star symbols to display my ratings.
Columns UI
Reply #3790
hello !
first, thanks for this great plugin.
it seems to have a problem with columns_ui and foobar 0.9.5 beta (1 and 2) : when I press "del" it does not remove the track of the playlist. if I switch to the default interface, no problem it works.
I use the last alpha version, same behaviour appends with the stable one. I use the navigator suite configuration.
list of my other components :
Core (2007-10-28 13:21:14)
    foobar2000 core 0.9.5 beta 2
foo_abx.dll (2006-12-16 13:52:46)
    ABX Comparator 1.3.1
foo_albumlist.dll (2007-10-23 22:36:22)
    Album List 4.1
foo_benchmark.dll (2006-08-04 20:56:56)
    Decoding Speed Test 1.0
foo_bitcompare.dll (2006-08-04 20:56:50)
    Binary Comparator 1.1
foo_burninate.dll (2007-07-12 18:48:14)
    Audio CD Writer 2.0.1
foo_cdda.dll (2007-10-23 22:36:06)
    CD Audio Decoder 2.1.2
foo_converter.dll (2007-10-23 22:35:52)
    Converter 1.0.1
foo_dsp_std.dll (2007-10-23 22:36:24)
    Standard DSP Array 1.0
foo_fileops.dll (2007-10-27 11:50:02)
    File Operations 2.0
foo_freedb2.dll (2007-08-16 16:27:44)
    freedb Tagger 0.5.2.1
foo_input_avs.dll (2007-07-12 18:48:15)
    AVS input 0.1
foo_input_std.dll (2007-10-25 22:56:28)
    Standard Input Array 1.0
foo_masstag.dll (2007-08-20 16:01:20)
    Masstagger 1.6
foo_msnalt.dll (2007-10-19 19:00:38)
    MSN Now Playing (alt) 2.4
foo_rgscan.dll (2007-10-22 22:58:18)
    ReplayGain Scanner 2.0.2
foo_ui_columns.dll (2007-10-26 17:47:31)
    Columns UI 0.2.1 alpha 3
foo_ui_std.dll (2007-10-28 13:20:38)
    Default User Interface 0.9.5
foo_uie_albumart.dll (2007-10-23 21:39:18)
    Album Art Panel 0.2.7
foo_uie_quicksearch.dll (2007-05-18 12:31:10)
    Quick Search Toolbar 2.8l
foo_unpack.dll (2006-11-04 14:17:06)
    RAR reader 1.1
    ZIP/GZIP reader 1.0
foo_verifier.dll (2006-08-29 21:09:16)
    File Integrity Verifier 1.0.1
foo_winamp_spam.dll (2007-07-12 18:48:19)
    Winamp API Emulator 0.90
Columns UI
Reply #3791
[quote name='kanak' post='525646' date='Oct 26 2007, 19:40']That makes sense... performance is priority no 1 . What about browsing by directory structure?  Suppose we have a path as follows:
[/quote]Hi,
Well I don't really want to invent a new scripting language (!) To be honest I'm not really convinced on directory browsing. However there are some tricks that can be used to mix in title formatting with current implementation (some version of album list did that). I didn't make any decision on that yet.
[quote name='sPeziFisH' post='525659' date='Oct 26 2007, 20:16']
edit: typo
[/quote]Hi,
I don't really have any issues with that. But, implementing it in that way will interfere with any single letter keyboard shortcuts. There is an alternative implementation if you don't like that..
[quote name='eddy@' post='525666' date='Oct 26 2007, 20:43']By the way, great job and great character, musicmusic.[/quote]Thanks
[quote name='Slotos' post='525667' date='Oct 26 2007, 20:45']
[/quote]I guess there's no point fighting the inevitable... But you should keep the grouping scripts as simple as possible for performance reasons. Globals are only going to slow things down as there are no columns here.
[quote name='Thief' post='525702' date='Oct 26 2007, 23:09']
Hi, I have a quick question: how to return selection borders in version 0.2+? they are shown when i press 'Ctrl' but disappear after foobar losts focus.[/quote]In one of the next builds it will be displayed always when 'Playback follows cursor' is enabled. Otherwise, you can make it display always when the playlist is focused by changing some system setting, it is covered elsewhere in this thread.
[quote name='Slotos' post='525886' date='Oct 28 2007, 03:43']
[a href="http://img178.imageshack.us/my.php?image=63592779ia0.gif" target="_blank"]
[quote name='4nt1' post='525888' date='Oct 28 2007, 04:51']another request for ngplaylist is to select an album by the group name, so I dont have to highlight every song, I just click on the group name.. [/quote]Yes, will be added.
[quote name='4nt1' post='525888' date='Oct 28 2007, 04:51']also in ng playlist is I select a song, hold shift and click the end of an album it does not select the whole album either it just highlights the bottom song... to me this is standard windows behavior that should be implemented... what do you think?[/quote]Hmm.. That would be a bug  Thanks for the report, I'll get that fixed.
[quote name='4nt1' post='525888' date='Oct 28 2007, 04:51']tagging from filter is also very sweet saves me lots of time and makes tagging a breeze, especially for finding badly tagged stuff... what are the future plans... so for filter what about inline tagging in the filter window itself... could be an interesting idea...
[/quote]Yes, inline was the idea
[quote name='joen' post='525959' date='Oct 28 2007, 15:14']1. The ability to put a button on the toolbar which envokes a drop down menu, like the ones already available for navigating backwards and forwards through tracks.
But with the ability to put the other button commands in the menu. This would allow for a less cluttered toolbar while also having a lot of functions available fast and it would allow to group related functions.[/quote]I agree it would be nice, but I'm not planning on making changes to the buttons toolbar a the moment. I noted it on the feature request page anyway. Though note it is possible for a component to provide a drop down button for the buttons toolbar.
[quote name='joen' post='525959' date='Oct 28 2007, 15:14']2. Having an entry in the View -> Layout menu to switch back to the previously chosen layout.[/quote]Sorry I doubt I'll add that.
[quote name='joen' post='525959' date='Oct 28 2007, 15:14']3. Overriding the font-type for specific columns. For instance I would like to use Wingdings in my ratings column so I can use star symbols to display my ratings.
[/quote]Well, I don't have anything against a rating column, maybe not your solution though. I noted it in requests list.
[quote name='MatMaul' post='526041' date='Oct 28 2007, 19:32']
hello !
I use the last alpha version, same behaviour appends with the stable one. I use the navigator suite configuration.[/quote]It seems like 0.9.5 removes those keyboard shortcuts, I can understand why anyway. It will be fixed at some point when I work on these 0.9.5 issues.
Too many quotes issues in forum gives me a headache
Namely because if I edit this post it will blow up, this is several post merged into one by forum..
Columns UI
Reply #3792
ok thanks
I just create a keyboard shortcut in the preferences and it works.
Like you said it is weird the developer remove it...
Columns UI
Reply #3793
Thanks for considering those musicmusic
Just a (possibly unneeded) clarification about my suggestion for a rating column. I'm using the "classic" columns playlist view and I added a rating column myself. Now I use $repeat(*,%rating%) in there. But of course some nice symbols would look much better there. So please consider making something like that possible in both playlist views.
Thanks for listening, and keep up the great work
Columns UI
Reply #3794
thanks for Filter panel, musicmusic! Works really fast with 9000 tracks collection. I have few issues with it. Single clicking on other than now playing Filter item replaces whole playback queue and "Activate now playing" feature loses it's functionality. is it possible to do something about it?
Columns UI
Reply #3795
I like your style, musicmusic.
You are maintaining your userbase very well :-)
Columns UI
Reply #3796
Can we have tagz expressions instead of fields in the filter?
Columns UI
Reply #3797
This was discussed two or three pages ago. At least for a while the answer is no.
Columns UI
Reply #3798
Hi there,
One of my first post, if not the first. I've been reading this forum for months now but can't really remember if I have participated...
First of all, I would like to congratulate musicmusic for his incredible work in developping ColumnsUI and having released a major component for this excellent program fb2k. (that's a bit too much... but it's just because of the way I turned it )
Then, thanks musicmusic for the implementation of the two new great features Filter and NG Playlist (I haven't had internet for the past 2 months... so they seam new to me) .
Nevertheless, there are two little requests I'd like you (musicmusic) to take into account.
[blockquote]- NG Playlist: ticker to hide columns title (as we used to be able to in playlist view)
- Filter: whenever I "browse" the filter panel, it brings up (focuses on) the Filter playlist... Ticker to enable/disable focus on filter playlist ?
[/blockquote]Thanks in advance.
Sorry for the possible english mistakes, my written english is usually pretty poor.
Edit@4h10 (Paris Time): Just thought that, in NG Playlist, it would be very handy to be able to collapse/expand the different groups we created. I mean, I created two groups, one for the artist, and one for the album title. It would be great to navigate through our library like that, just open an artist, an album, choose your song...and that's it !
I guess that's VERY complicated to implement... but hey, never know.
