Topic: Columns UI (Read 4615355 times) previous topic - next topic
0 Members and 13 Guests are viewing this topic.
Columns UI
Reply #3625
can someone post a link to columns and for what version of foobar it is for
Columns UI
Reply #3626
God! ! !
Do not enable them both through Columns UI to do so at any resolution screen window foobar2000 was always centered?
Columns UI
Reply #3627
Bug:
I noticed this a few versions ago, but when I have my playback order set to default, or shuffle tracks, or anything really except to repeat a track, when the LAST song on the playlist is played (the very bottom song) foobar wont skip to another song, but will act as if I pressed stop or something. It stops playing music. I can go in and choose another song, or press random or whatever and everything is fine again until the bottom most song is played.
Does anyone else have this issue? I am posting it here cause I haven't tested this with the default layout, or with SCPL, so I think it may be a CUI problem.
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
Columns UI
Reply #3628
Bug:
as far as I know it's normal, because Default will just play the playlist, nothing weird about that.
and if Default will repeat the playlist, the option Repeat playlist is useless, because it's similar.
so you need Repeat playlist.
Columns UI
Reply #3629
Bug:
No, what I mean is, that when my foobar plays the last track on my playlist, playback stops. It doesn't play anything else no matter what playback order I have chosen. I do see your point about default should end on the last song, but when I have 'repeat playlist' selected, and the last song on my playlist is played, playback still stops; no repeating.
I almost ALWAYS have 'shuffle (tracks)' selected, and when the last song is played on my playlist, playback stops when it is done. I don't really know how else to explain it.
If you wanted to try it for yourself, set your playback mode to 'shuffle (tracks)' and play the last song on your playlist. Playback should end.
Columns UI
Reply #3630
I cannot reproduce this problem with SCPL, CUI 0.1.3 beta 1 v7, CUI 0.2.0 alpha 2, or the DefaultUI's playlist.
elevatorladylevitateme
Columns UI
Reply #3631
Hi. I was playing a little bit with my config and i've wanted to put foo_uie_peakmeter into my layout.
But I don't know how do modify my current setup that looks like this:
[a href="http://xs.to/xs.php?h=xs117&d=07281&f=layout.png" target="_blank"]
Columns UI
Reply #3632
Insert a Vertical Splitter over the Track Info and then move the Track Info inside the splitter, then add the Peakmeter under Track Info(also in the splitter).
Columns UI
Reply #3633
Thank you very much sir
Columns UI
Reply #3634
musicmusic, can you please fix an old bug, which has been introduced a couple of versions ago?
- when a track is playing and you reload it's playlist entry while it is playing, e.g. by performing a database search, columns UI does no more display it in playing mode. It does display it as if it was stopped.
Columns UI
Reply #3635
I think you are referring to the %isplaying% change in foobar2000 0.9. That info comes from the core (playlist engine) anyway.
Columns UI
Reply #3636
I have this issue also, and its a pain. I bind my main playlist (which is all my music) often because I am always adding new stuff. However, if a track is playing, after the bind (or pretty much any update to the playlist) the song that WAS playing is no longer highlighted.
I am not sure how this would affect %isplaying%, musicmusic. I don't think it has anything to do with any tags? Could you explain in more detail how to keep my playing song selected after a playlist update?
Columns UI
Reply #3637
I said %isplaying% but there's also the internal playing item marker. To put it simply when you clear/replace the playlist (or otherwise remove the playing item) the marker is reset. In 0.9.x %isplaying% follows the playback marker, it was different with %_isplaying% in 0.8.x.
%isplaying% is what the default playlist script uses to highlight the playing track.
There was some discussion about changes to %isplaying% in 0.9 a while ago, though I can't find it. But like I said, this isn't controlled by Columns UI.
Disclaimer: This is all "as I remember", this stuff was some time ago
Also 0.2 alpha 3 released.
God! ! !
Sorry, I didn't understand. Can you elaborate?
Columns UI
Reply #3638
Thanks for the new version with the built in tabs.
Just a little minor cosmetig thing, the panels inside the stack is padded so it's a white frame around it.
And if you have the menu inside you won't be able to reduce the width lower than the menu's width.
It would be great if you could bind a hotkey to it, to switch to a tab or cycle it.
Columns UI
Reply #3639
FCL exporting question:
I'm currently using this layout:
While trying to export FCL, i get this error:
Missing child panel of splitter!
What's going on?
Columns UI
Reply #3640
nice update. the tabs will fix a few bugs for me related to the tabbed panel stack mod plugin. would it be possible to hide the tab bar and have no borders? thanks.
Columns UI
Reply #3641
OK, as far as I understand you "%isplaying%" doesn't help as well and indeed, after replacing %_isplaying% with %isplaying%,  this doesn't help. As this is fb2k core dependent I assume we'll never get the old behaviour back. Thanks anyway.  And thanks for a3.
Columns UI
Reply #3642
thanks for new version
everything seems to works fine.
Columns UI
Reply #3643
It is using the standard tabs control positioning. I can maybe change it to same as playlist tabs, if it looks OK.
Yes, it's by design.
What's going on?
Check your other presets. It exports all of them.
For the latter see above. For the former why would you want to hide the tab bar?
Columns UI
Reply #3644
first of all thank you so much musicmusic for the new release.
I want to second the request of having no borders around the Tab Stack. Can you add support for keyboard hotkeys to switch between the tabs and the option to hide the Tab Bar, like in tabbed panel stack mod plugin?
That would be great.
Columns UI
Reply #3645
for example, i have three different layouts for foobar. one for viewing on my monitor in high res, and 2 layouts with large fonts for viewing on the tv (one for browsing files and one for the playlist). i assign each layout to a tab, and then a keyboard shortcut for each tab. i use my remote to send the keyboard shortcuts to switch the tabs so i practically never use the actual tabs, but the functionality they bring. i know your component doesnt allow you to assign keyboard shortcuts to each tab so hiding the tabs wouldn't really be of much benefit anyway now that i think of it. the tabbed panel stack mod created a few bugs that do not exist in your version of tabs so i was excited to see the direction it was going.
Columns UI
Reply #3646
0.2 beta 1 released, see changelog for details.. Difference between "Any" and "This" installation in FCL export is same kind of thing as FCB embed images vs. store paths.
Also foo_uie_typefind has returned. I added a Query search mode, which uses the filter syntax (i.e. same as autoplaylist).
Hi, well I am sure you can understand a tab stack without tabs is not really a tab stack
If your complete layouts are stored in these fake tabs (in Columns UI) you should just use the layout system, you can assign shortcuts to those.
In regards to shortcuts, I enabled the use of the left and right keys to switch tab (when focused) in beta 1.
Columns UI
Reply #3647
Thanks for the update. Is the FCL format final now?
Columns UI
Reply #3649
Thanks, musicmusic for fixing the borders in tab stack, works great now.
