Topic: Lame command line (Read 5575 times) previous topic - next topic
Lame command line
Hey, i've tried writing a lame command line that will write the id3 tags from the file name, but havent' been able to get it to work.  Can someone help me out.  I like to have v1 and v2 tags.  I'd appreciate it
Lame command line
What I mean is that I can't get it to write the tags at all.  I'm not necessarily trying to write the command line in the tag.
Lame command line
No prob.
Lame command line
Unless you have a particular desire to use the command line encoder, you could use lamedropXPd, either 3.92 or 3.93alpha, from here: http://www.inf.ufpr.br/~rja00/mp3.html which has a tagging facility to do just what you want. Both versions use the standard lame libraries.
Lame command line
I must be missing something cos I can't get it to write ide tags
argh!!
Lame command line
had problems with ID3 too
my command line in EAC is
--alt-preset extreme --id3v2-only --pad-id3v2 --tt "%t" --ta "%a" --tl "%g" --tn "%n" %s %d
Lame command line
Don't know if i understood your question correctly! But if you're talking about a commandline that you would use to call LAME.exe separately it wouldn't work. LAME.exe itself can't read information out of the filename. You need to have a 'frontend' like EAC that can do it!
With EAC it would work the way XENION described, where %a, %t, etc. are variables that are known by the 'frontend'
Those who desire to give up freedom in order to gain security, will not have, nor do they deserve, either one! (Benjamin Franklin)
Lame command line
dreamliner77,
I don't know why you want to use lame to perform this task, but it can be done by Tag .
Get a frontend for Tag
here
Lame command line
I think EAC writes the ID3-Tags automatically. Why use a command line for this anyway?
Lame command line
it sure does, all I have in EAC is
--alt-preset standard %s %d
Lame command line
EAC doesn't write any tags automatically.
but the use of id3 tags are default.
just to clear up confusion...
mike
Lame command line
@xmixahlx
That means, that EAC _can_ write ID3-Tags, doesn't it? So I have to correct myself:
"EAC can write ID3-Tags, if you like. So there is no need for lame-command-lines with tagging."
Lame command line
The problem with EAC and writing tags is that it cannot write ID3v2 without ID3v1 tags. So, if you want to have a file with only a ID3v2 file, you will have to use extra command line options in EAC to let LAME write the tag and tell EAC not to write it.
Sikke
Lame command line
Ähhm... It doesn't matter, if EAC can only write both or none, does it? IIRC there are "some" older players, that can't handle ID3v2-tags (e.g. my mobile phone).
So it's not a bug, it's a feature ;-)
Lame command line
I would still prefer the hability to choose ID3v1 OR ID3v2 OR Both OR None.
For instance, in_faad can handle ID3v2 tags, but, for some bizar reason only Menno knows why, it chokes on ID3v1. For that reason, I recommend people to rip and tag with CDex when encoding with Psytel.
CDex allows choosing ID3v2 only.
Lame command line
I like to choose myself which tag is written. Some programs default to v1 if both tags are present, so names are cut off when longer then 30 chars etc. Having mp3's with only v2 tags is the solution in those cases...
Sikke
Lame command line
I can only speak for myself, but I hate those only-id3v2-mp3s (and no those untagged files too), if there's no .sfv file included. There's so many broken mp3 files floating around communities that you can't figure out if they're complete or not (even after searching your ass off for tracklengths on google/cddb for the specific album). When a ID3v1 tag is added in the end of the file you can at least see if the file is complete or not. Sollution #2: everybody starts including .sfv files. But how likely is that?
Lame command line
I only make my own mp3s from my CDs, it doesn't seem like anyone uses lame & --alt-preset standard anyways, pretty much every single mp3 I've ever downloaded has been crap to worse than crap.
Lame command line
Nearly 50-60% of the MP3-albums available in filesharing networks is provided with a .sfv. (Atleast if you use DirectConnect, and get into good hubs.... ~70% of those are lame encoded, but all with -b 192 -ms...)
But, .sfv uses only 32 bits for its checksum, which may not be enough; check my posting here  . Use md5 instead (uses 128 bits)!
Lame command line
If you want to use MD5 verification files, I suggest using .par (Parchive)
More info here:
http://parchive.sourceforge.net/
Lame command line
You've got to look at the right places. There's atleast one community where people only use --aps/--ape.
Lame command line
You're talking scene releases? I'd rather stay away from them, if I could. Anyways, thanks for the md5 tip, I'll check it out.
