Topic: Is EAC a good CD-burner? Does it burn DAO? Is Feurio better (Read 4764 times) previous topic - next topic
I've tried Feurio but i don't dig a thing about it so i use EAC to burn.
I'm always doing my best to get well-burned CDs (EAC secure ripping, expensive CD-r, 2x burn) so I'd like to use the best to burn.
Is EAC a very good burner?
Does it burn with Disc-at-once mode?
Is feurio better? (if yes, how can i use cue sheet with it?)
If you wanna use Cue sheets, try CDRWin
Yes it is only burner which can correct write samples offset I have seen.
Thanks but I'd like to go with EAC or maybe Feurio
Yes, EAC burns in DAO mode. I use it quite often, and also Feurio, both with excellent results.
Yes, but it has some compatibility issues with lots of recording drives.
You're telling me... It seems to "think" to support my Philips 8x CD-RW drive, but when It tries to burn brings up some error.  It does recognize it as a burner, so maybe there will be support in future versions, and this may just be a placeholder of some sort.
Originally posted by ears
Make sure you've got the latest version:
studserver.uni-dortmund.de/~su0165/eac09b4.exe
or the older stable version
www.exactaudiocopy.de/eac09pb11.zip
Prebeta 3 caused write errors with my Teac 24x but prebeta 4 cleared it all up.
Oh, I've got the latest version, I have been using EAC for a pretty long while now and every new version I'm just like "Ooh, maybe this is it!" but every time the same error...
"Write error !
Set Write Parameters :
Invalid field in parameter list"
EAC does know when I have a CD-R in the drive, but it wont burn.  I have posted on the EAC forum and Andre Wiethoff himself has replied saying that Philips drives are not currently supported.  I will find the post in a few minuites.
The post was here
