Topic: Looping input module positioning (Read 2688 times) previous topic - next topic
I've made a fairly simple input component (for the ADPCM files used by Square/Enix in PlayOnline).  Given that these files containing looping information, I added optional looping playback - this all went easily enough.
The problem I have, however, is that when playback reaches the end of the file, and jumps back to the loop start, foobar's location slider stays at 100%, and the playtime and progress indicators happily continue to count onwards.
Is there any way I can tell foobar I'm looping so that it can reposition its location slider and/or update the time/progress indicators?  Or should I set length to 0 if looping is enabled (as it effectively amounts to streaming).
[a href="index.php?act=findpost&pid=231616"][{POST_SNAPBACK}][/a]
Not at this time.
I wouldn't suggest doing that, as it would be inconsistent with other software which currently displays the correct length whether or not toe format is looping.
You might also want to take a look at the flags passed to input::open(), as they will tell your decoder instance whether it should not loop forever, ie. user is converting the file or running it through the ReplayGain scanner.
Feel free to download the source code to foo_festalon from my components page to see how its open() call combines a flag check with a configuration variable check, then performs length checking with an optional fade-out. It may not be the best example, but it works.
[a href="index.php?act=findpost&pid=231804"][{POST_SNAPBACK}][/a]
I already do that - I have a config variable (and corresponding checkbox on a config page) to enable/disable looping, and the open flag is checked to override that variable when needed.  I'm also planning to add a configuration option to set some maximum number of loops (in which case I can compute a 'correct' total length again).  I was merely hoping there was some "clean" way of handling inifinite looping.
Which reminds me, I still need to update my seek() implementation to take looping into account ^^
