Topic: Dial-up bitrate listening test - Finished! (Read 29402 times) previous topic - next topic
Reply #50
Same for me. The SBR tool offers a strange texture (graininess) and is maybe responsible of the extra-noise which irritated me very much; Parametric Stereo is also the cause of an incoherent stereo image in my opinion. Therefore, AAC was not far from the last place on the ~10 samples I've rated.
I must add that I have a lot of troubles to rate poor files with so obvious and so different artifacts. That's why I never sent results to Ivan for the two small listening tests he launched some months ago. I'm sure that my results are extremely dependant on my mood: sometimes I would prefer extreme lowpass to any artifacts, and sometimes high frequencies -even bad- would be prefered to lowpassed sound. During Roberto's test, I prefered lowpassed but ~natural sound to the colorized WMA/SBR sound.
Reply #51
Good comments, I found myself at a loss at times too...."which artifacts are more irritating? The decrease in frequency range or the greater frequency range + added noise + altered stereo image?"  WMA sometimes offered a happy medium in my case (or maybe my attention waned ).
Reply #52
At last!
Here is the plot for music samples only:
As you can see, QDesign performs considerably better, getting slightly tied to MP3pro.
And the final plot with Anova analysis:
The winners and losers remain the same, but the error margins are now smaller.
I won't add the latter graph to the page, to avoid confusion.
Regards;
Roberto.
