Topic: Freedbwise type of custom application... (Read 3055 times) previous topic - next topic
We are looking at a custom system for tagging, cataloguing, searching, etc. audio files of French cultural radio broadcast sessions... in a way similar to how things are organized around freedb for standard CD music numbers management purposes.
Is it therefore possible to set up a specific freedb-like type of database that would be customized to radio specific information and then have foobar2000 to automatically extract/feed tag information from this database?
In another word, can foobar2000 be linked to a customized database that is not freedb?
Thank you so much for your help!
radionysos@yahoo.fr
In another word, can foobar2000 be linked to a customized database that is not freedb?[a href="index.php?act=findpost&pid=228180"][{POST_SNAPBACK}][/a]
Yes, this is possible if one writes a plugin to get the infos from this specific database (this is also the way, the freedb support is implemented).
Best regards,
~ Florian
Thanks Florian!
additionnal questions though...
1) What developing tool should be used for developing such a utility? Are they foolbar2000 built in?
2) How much expertise is needed? Do you need to be a confirmed developer or can anyone pretty good computer litterate can survive it?
3) What db should we be using for the central db? Would we need to entirely develop such a db from scratch (ie. SQL) or can we start from a freedb model and simply customize it to our own needs?
Kind Regards,
radionysos
All foobar2000 plugins written in C/C++ and are based on foobar2000's great SDK (which is avaliable at the main page). You can use MSFT's Visual Studio as development tool.
foosion wrote a small plugin development tutorial and there are tons of plugins with source code available.
freedb uses files as database and I think that the development effort with using such an approach is much bigger, than using a already existing database (like the public domain database sqlite) which provides SQL for querying the data.
Best regards,
~ Florian
thanks for your answer Florian!
This is perfect answer and the quickest ever one I've seen so far!!
