Topic: Total Times Played Counter (Read 2839 times) previous topic - next topic
The total played counter, the rightmost column in Colums UI isn't working. I'm not 100% sure if this is where to post but I'll give it a go.
I've looked through the code, but as I don't code, I didn't understand much of it.
I need to get the amount played counter working for the tracks. I don't know if it needs activating or what.. I'm kinda confused.
Thanks in advance & any help is greatly appeciated.
Just paste that into the UI Column you want to show the Counter:
[%PLAY_COUNTER%,4]
It will show if it exist: if there's no count, aka never played song, it will be empty. If you want to show a 0 count, just paste that (%PLAY_COUNTER%,4) (without the []).
It will show up in that form 0010 for 10 times played song. If you want something like 10 just change the 4 by 2 ([%PLAY_COUNTER%,2]) or the quantity of numbers you want to show up
i didn't know there was a plugin :-\
Is it on the component page? I'll take a look. Also, jkwarras, thankd for the help d:
[a href="index.php?act=findpost&pid=224292"][{POST_SNAPBACK}][/a]
No problem
the counter plugin isnt on the component page . Where would I find it?
I found it about 2 seconds before you posted where lolz. Thanks for the help. Got it working
