Topic: VS2003 & 0.8.2SDK & Win32 dll (Read 5227 times) previous topic - next topic
Hi!
I use VS .net 2003 and foobar 0.8.2.
I did this:
1) Choose New Project->Win32 project->Dll, named it foo_my
2) Add component_client.cpp to foo_my
3) Add projects foobar200SDK, pfc, utf8api
4) Set dependences: foo_my -> foobar2000SDK
   Foobar2000SDK -> pfc, Foobar2000SDK -> utf8api
5) Disable precompiled headers
6) Select Release
And than I got following:
------ Build started: Project: utf8api, Configuration: Release Win32 ------
Linking...
  Creating library .\../Release/utf8api.lib and object .\../Release/utf8api.exp
crash_info.obj : error LNK2019: unresolved external symbol "unsigned int __cdecl strlen_max(char const *,unsigned int)" (?strlen_max@@YAIPBDI@Z) referenced in function _uPrintCrashInfo
systray.obj : error LNK2001: unresolved external symbol "unsigned int __cdecl strlen_max(char const *,unsigned int)" (?strlen_max@@YAIPBDI@Z)
Huge of LNK2019 and others!!!
string_base::skip_trailing_char(unsigned int)" (?skip_trailing_char@string_base@@QAEXI@Z) referenced in function _uGetOpenFileNameMulti
.\../Release/utf8api.dll : fatal error LNK1120: 17 unresolved externals
utf8api - 26 error(s), 0 warning(s)
------ Build started: Project: foo_my, Configuration: Release Win32 ------
Linking...
MSVCRT.lib(MSVCR71.dll) : error LNK2005: _free already defined in LIBCMT.lib(free.obj)
MSVCRT.lib(MSVCR71.dll) : error LNK2005: _realloc already defined in LIBCMT.lib(realloc.obj)
MSVCRT.lib(MSVCR71.dll) : error LNK2005: _malloc already defined in LIBCMT.lib(malloc.obj)
MSVCRT.lib(MSVCR71.dll) : error LNK2005: __i64toa already defined in LIBCMT.lib(xtoa.obj)
MSVCRT.lib(MSVCR71.dll) : error LNK2005: __ui64toa already defined in LIBCMT.lib(xtoa.obj)
MSVCRT.lib(MSVCR71.dll) : error LNK2005: _atoi already defined in LIBCMT.lib(atox.obj)
MSVCRT.lib(MSVCR71.dll) : error LNK2005: __ultoa already defined in LIBCMT.lib(xtoa.obj)
MSVCRT.lib(MSVCR71.dll) : error LNK2005: __itoa already defined in LIBCMT.lib(xtoa.obj)
MSVCRT.lib(MSVCR71.dll) : warning LNK4006: _free already defined in LIBCMT.lib(free.obj); second definition ignored
MSVCRT.lib(MSVCR71.dll) : warning LNK4006: _realloc already defined in LIBCMT.lib(realloc.obj); second definition ignored
MSVCRT.lib(MSVCR71.dll) : warning LNK4006: _malloc already defined in LIBCMT.lib(malloc.obj); second definition ignored
MSVCRT.lib(MSVCR71.dll) : warning LNK4006: __i64toa already defined in LIBCMT.lib(xtoa.obj); second definition ignored
MSVCRT.lib(MSVCR71.dll) : warning LNK4006: __ui64toa already defined in LIBCMT.lib(xtoa.obj); second definition ignored
MSVCRT.lib(MSVCR71.dll) : warning LNK4006: _atoi already defined in LIBCMT.lib(atox.obj); second definition ignored
MSVCRT.lib(MSVCR71.dll) : warning LNK4006: __ultoa already defined in LIBCMT.lib(xtoa.obj); second definition ignored
MSVCRT.lib(MSVCR71.dll) : warning LNK4006: __itoa already defined in LIBCMT.lib(xtoa.obj); second definition ignored
I don’t want to use MFC Dll, I just moved from BCB and I’ve never worked with MFC, I need a simple dll (for a start  Thanks for any help!
P.S
Sorry, if there are any grammatical mistakes
1) you should add the foobar2000_component_client project to your workspace and make your project dependend on it instead of directly adding component_client.cpp.
2) You should use the same version of the runtime libraries as the static libraries you link against, i.e. use multithreaded dll runtimes like foobar2000_sdk and foobar2000_component_client. (Look for "C++/Code generation" in project settings.)
Thanks! I did so. It works, but not at all. I add component_client project and set "foo_my->runtime library->Multi-threaded DLL (/MD)". And foo_my was compilled successfully, but I still have the same problems during utf8api compilling. Should I do something else?
Now it works! Thanks a lot!
