Topic: DVD Rebuilder (Read 5233 times) previous topic - next topic
DVD Rebuilder
[span style='font-size:8pt;line-height:100%'](Overview)[/span]
DVD ReBuilder was built to bridge the gap between the incredibly easy but limited "one-click" solutions and the incredibly complex but high-quality methods of DVD ripping and backup.
A major advantage of DVD-RB when compared to older methods is that it doesn't require access to an expensive authoring package. DVD-RB includes its own authoring engine that reconstructs the DVD in a way compatible with its original design.
DVD ReBuilder is currently in beta form and undergoing heavy development by it's author, jdobbs.
DVD Rebuilder combined with Cinemacraft Encoder produces very high quality "one-click" DVD-9 to DVD-5 video copies & will only cost you $59 (price of CCE) it is however currently also the slowest.
[span style='font-size:8pt;line-height:100%'](Changes)[/span]
- Corrected error in which the "all contents of VIDEO_TS..." message was not suppressed when "Suppress Warning Prompts" was selected. Thx to jhmac.
- Changed output to .ECL files so "seq_endcode=1" is set for still frames this has been reported to fix problems associated with stills and BOV. Thanks to wmansir and Sir Didymus for researching, finding, and testing this fix.
- Corrected an error associated with CCE Basic that caused a "cce encoding failed: MPVA ... qsv 112 > 112" -- caused by an average bitrate that was calculated to an exceptionally low value.
- Fixed an error in which only the last two digits of the segment number were displaying in the status window. Thanks to jptheripper for catching this.
- Fixed error in which the the "Shutdown" options were not working correctly with Windows 2000 computers (stopped at the "SAFE TO REMOVE POWER" prompt). Thanks to archaeo for pointing out this error.
Doom9.org hosts the DVD Rebuilder forum, bug reports can be  posted here & a guide can be found at Doom9.org
DVD Rebuilder
Ooh...
*Except for quality*
"Taking a jazz approach and concentrating on live playing, I wanted to use several different rhythm sections and vintage instruments and amps to create a timeless sound that's geared more around musicality and vibe than sonic perfection. The key was to write with specific rhythm sections in mind, yet leave open spaces for soloing." Lee Ritenour
