Topic: Playlist problem...? (Read 1603 times) previous topic - next topic
hi, I'm using the lastest version foobar 2000.
And I made serveral playlists.  There is no problem if foobar excute at first.
However on Exploerer if I double-click some mp3 or ogg file, foobar delete playlist excuted lastly and re-list the file.
So I have to re-make the playlist again.
I want to keep the playlist though it excute by double-clicking.
I don't know how to do it.  Give me a proper way.
Look under Prefences -> Core, and you'll see "Always send to playlist" and "Enqueue incoming files by default when adding from commandline".
You can use "Always send" to herd all your files into a specific playlist, so that you can preserve the files in your other playlists, but the problem is, the playlist you had chosen won't be preserved. If you use "Enqueue", your playlists will all be preserved. : )
Mix and match as you would prefer.
Use the search, Luke ™
