Topic: Volume control (Read 3540 times) previous topic - next topic
Volume control
I think that a volume control will be very usefull on Foobar2000.
What does You think?
Best regards.
Andreiko
Volume control
there is one,  use the - and + either on the numpad or just the top keys, but i would like a visual volumebar
Volume control
Preferences - playback is the closest you're probably ever gonna get.
Someone could code up a visual volume bar extension, that would probably be pretty handy...
Volume control
hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys hotkeys .....
NUM+ NUM-
when will this ever end........
Volume control
Maybe there should be made a sticky:
"DON'T ASK ABOUT VOLUME SLIDER!!!"
Volume control
the first rule of Volume Slider is you do not talk about--
..ah, to hell with it. just use fooTunes.
Volume control
IMHO a good non-obstrusive approach to the volume slider is to make the wheel mouse modify the volume when scolling hovering the volume zone in the status bar.
Volume control
If you feel like changing UIs, foo_tunes has a volume bar.
