Topic: Multiformat@128kbps public listening test - OPEN (Read 36961 times) previous topic - next topic
Reply #100
We've got to the end of the week to test 18 samples?
Please Roberto give us some more room... I've got a job!
Reply #101
I assume it's not necessary to test all 18 samples. At the end of the week, just send the results of the tests you managed to complete.
Over thinking, over analyzing separates the body from the mind.
Reply #102
I know that, but I would like to test them all. And I guess that the larger number of results the more valid the result should be...
Reply #103
dunno if this was discussed already, but the .torrents seem to be removed, from the normal sample download, sample16 doesnt seem to be downloadable
Reply #104
I removed the .torrents because if someone is going to start the test now, he should be hurried, and therefore he should use the http links. But the tracker is still working.
About the sample packages: they are there:
http://www.rarewares.org/samples/
I guess the problem you experienced is related to rarewares.org moving to another server.
Reply #105
24 hours to go
In about 24 hours, this test will be closed.
If you don't plan to test more samples, please start sending your results.
Regards;
Roberto.
Reply #106
results sent
Reply #107
Could somebody enlighten me on details of kraftwerk sample? (Sample10)
I need album and track name.
Thank-you in advance.
Reply #108
Album: The Man Machine
Title: The Robots
Tracknumber: 01
Date: 1978
A properly remastered reissue of this album (and other Krafwerk's albums) is expected soon.
Reply #109
Amount of results I got so far, for those interested:
Sample01: 21
Sample02: 23
Sample03: 22
Sample04: 23
Sample05: 17
Sample06: 17
Sample07: 15
Sample08: 17
Sample09: 19
Sample10: 25
Sample11: 13
Sample12: 12
Sample13: 13
Sample14: 14
Sample15: 14
Sample16: 11
Sample17: 15
Sample18: 13
That is before screening for ranked references, mind you
I'm afraid that testing 18 samples wasn't a good idea, after all.
Reply #110
Sample01: 21
Sample02: 23
Sample03: 22
Sample04: 23
Sample05: 17
Sample06: 17
Sample07: 15
Sample08: 17
Sample09: 19
Sample10: 25
Sample11: 13
Sample12: 12
Sample13: 13
Sample14: 14
Sample15: 14
Sample16: 11
Sample17: 15
Sample18: 13
Why not?  Numbers around 12 per sample aren't unexpected or even necessarily bad.  My opinion before the test was that it would be better to have numbers like this on more samples than a higher number of listeners on fewer samples.  Also, the test can be extended to help increase numbers if you process them and still think it's problematic.
ff123
Reply #111
LAST CALL
The test will finish in less than one hour. If you still have results to send, send them ASAP.
Reply #112
Got mine in just under the wire.
My results are pretty pathetic, but I'm not surprised.  I think my personal transparency threshold is somewhere around 48-64kbps.  I'm convinced I have "artifact-proof hearing".
Thanks to Roberto for conducting this test.  He's done a great job yet again.
Reply #113
Test is now CLOSED.
Results will be published quite shortly. Huge thanks to all participants.
Reply #114
I will be a show ruiner and reveal that Vorbis (AoTuV tweak) enthusiasts will be very happy...
Juha Laaksonheimo
