Topic: Question about ReplayGain (Read 1577 times) previous topic - next topic
When we speak about dynamic range in CDs we know that CDs has a maximum dynamic range of 96 dB (6*16). Assuming that -96 dB is the lowest volume and 0 dB is the highest, I was wondering if it is correct to consider 100 dB in ReplayGain equal to 0 dB of medium volume level and so 89 dB in RG equal to a medium volume level -11 dB and 4 db in RG equal to a medium volume level of -96 dB? I know that it can be a silly question but I wanted to be sure about this...Thanx for answers
Hi vize84,
That's not a silly question at all. In fact, it's not a trivial question to answer.
The best post I can find on it is here:
http://www.hydrogenaudio.org/forums/index....pic=15445&st=41
In that thread, someone suggested changing the ReplayGain values so that they were tied to 0dB FS on CD. The discussion explains the difference between the values on CD, the ReplayGain value, and the relationship between the two. If you read it, I think it'll answer your question.
Hope this helps.
David.
