Topic: Dolby ProLogic 2 (DS2) (Read 12465 times) previous topic - next topic
@user
i have uploaded some good ac3 testfiles that i've created with matlab.
you can use it to easily see the effect of my downmixer on each channel seperatly.
link :
http://dspguru.notrace.dk/dgtestfiles.zip
I have downloaded and unzipped. Each ac3 file is about 4 seconds, that's fine for burning waves to CDDA with Nero, as Nero has a limit of 2 seconds per wave.
You have got PM.
Yeah,
I confirm that surround (rear) left and surround (rear) right channels are separated.
It seems after some testing, that plugin works fine.
The separation is probably the same as got by DS2 of headac3he0.23.
umm, why have I not been able to hear it some time earlier ?!
Perhaps some errors in my command line....
The working line you can find in logfile:
One example:
d:own filesmoviesprogramsBeSweet ac3 to mp2
BeSweet.exe -core( -input d:own filesMy MusicAC3tests 5.11 channel ac3sl.ac3 -output d:own filesMy MusicAC3tests 5.1sl.wav -2ch -logfile D:own filesmoviesprogramsBeSweet ac3 to mp2BeSweet.log ) -plugin( -name BS_Downmix.dll -func NoLFE -6ch -azid( -s surround -L 0db -S 0db --maximize ) -ssrc( --rate 44100 --twopass )
BeSweet v1.4b1 by DSPguru.
Using azid.dll v1.8 (b825) by Midas  (midas@egon.gyaloglo.hu).
Using ssrc.dll v1.28 by Naoki Shibata & Dg (shibatch@geocities.co.jp).
Using BS_Downmix.dll v0.1 by DSPguru (http://DSPguru.doom9.org).
Logging start : 06/16/02 , 01:28:02.
d:Eigene DateienFilmeDVD Video Audio ProgrammeBeSweet ac3 to mp2BeSweet.exe -core( -input d:Eigene DateienMy MusicAC3tests 5.1dspguru 1 kanal ac3ssl.ac3 -output d:Eigene DateienMy MusicAC3tests 5.1sl.wav -2ch -logfile D:Eigene DateienFilmeDVD Video Audio ProgrammeBeSweet ac3 to mp2BeSweet.log ) -plugin( -name BS_Downmix.dll -func NoLFE -6ch -azid( -s surround -L 0db -S 0db --maximize ) -ssrc( --rate 44100 --twopass )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] |  Input : d:Eigene DateienMy MusicAC3tests 5.1dspguru 1 kanal ac3ssl.ac3
[00:00:00:000] |  Output: d:Eigene DateienMy MusicAC3tests 5.1sl.wav
[00:00:00:000] |  Floating-Point Process: No
[00:00:00:000] +-------- AZID -------
[00:00:00:000] |  Output Stereo mode: Dolby surround compatible
[00:00:00:000] |  Total Gain: 0.0dB, Compression:  None
[00:00:00:000] |  LFE levels: To LR 0.0dB, To LFE 0.0dB
[00:00:00:000] |  Center  mix level: BSI
[00:00:00:000] |  Surround mix level: BSI
[00:00:00:000] |  Dialog normalization: No
[00:00:00:000] |  Rear channels filtering: No
[00:00:00:000] +-------- SSRC -------
[00:00:00:000] |  Source Sample-Rate: 48.0KHz
[00:00:00:000] |  Dest.  Sample-Rate: 44.1KHz
[00:00:00:000] |  Attenuation      : 0.0db
[00:00:00:000] +---------------------
[00:00:04:352] Conversion Completed !
[00:00:04:352] Actual Avg. Bitrate  : 1420kbps
[00:00:03:000] <-- Transcoding Duration
Logging ends : 06/16/02 , 01:28:05.
Great .
