Topic: Play Counter (Read 342128 times) previous topic - next topic
Play Counter
Reply #600
Uhh... all of a sudden my playcount isn't updating. I can't give any more info than that, it's just... stopped updating. Help please?
err... i'm not using windows any more ;)
Play Counter
Reply #601
played %play_counter% times$char(10)
last played %first_played% $char(10)
Play Counter
Reply #602
enabling the "Automatically synchronize file tags with statistics" option helped for me.. (although it sometimes causes a little higher cpu-usage)
maybe you should have a look a the properties dialog of some song - maybe your script is using another tag than your version of the foo_playcount-plugin?!
Hope this helps!
Andreas
Play Counter
Reply #603
There is a new version on the server.
Does anybody know what is new?
Thanx
Play Counter
Reply #606
@Just Elliott
hmm. not working here either. Anyone know what's wrong? maybe we should just bite the bullet and start using the official play counter or something
Edit: Found the solution. Use the updated version of the unofficial play counter.
Download dll
Here's where i found the solution: HA Thread Link
Also, the metadb leaks are gone.
wohoo!
Play Counter
Reply #607
I've already bit the bullet and am using the official play counter  No regrets either. It's much better than it originally was.
Play Counter
Reply #608
2OCedHrt
I fully agree with you
Play Counter
Reply #609
how can i display date but without hour?
Play Counter
Reply #610
Does the official updates the tags?
Does the official work without the Media Library?
Play Counter
Reply #611
Official updates tags if you set it to. Otherwise it just writes to the database.
Play Counter
Reply #612
is this plugin still being updated? if so, tags arent updated if foobar is restarted while a song is playing. assuming its restarted before the update should happen. and also, is ther eanyway to get rid of that damn annoying tag updating window?
Play Counter
Reply #613
Tags shouldn't update if foobar restarts before it should be updated. Read what you just wrote again. And yes, by using the official playback statistics instead.
Play Counter
Reply #614
this plugin used to leave a tmp file in foobars directory to indicate if it was playing, but not updated in the case foobar is restarted. some people have chosen foobar to resume playback on startup and in this case, the files do not get updated. also, the official plugin lacks too many options not to mention the fact that the tag it generates is useless to me..
Play Counter
Reply #615
Working with resume playback after restart is probably just something that was overlooked. However, the official plugin writes every tag the unofficial plugin writes.
Play Counter
Reply #616
ok, ive figured out that %last_played% will display a readable date format and %last_played_timestamp% shows this strange format. what format is it?
is it possible to convert all my old tags from 2006-10-15 15:30:41 to this format?
Play Counter
Reply #617
@gob
for converting from old format (DATE) to new format (TIMESTAMP) have a look
HERE
AND HERE
Play Counter
Reply #618
ive seen this before but the thread is in the general (fb2k) forums lol. thanks for pointing this out.
Play Counter
Reply #619
Is there any way to supress the "updating files" window when it updates the playcount?? It keeps stealing focus from other programs..
Play Counter
Reply #622
the official playcount plugin doesn't have the same behavior as the unofficial does... am I wrong?
I don't want to use a database and I want it to update on the middle of the playing music...
Play Counter
Reply #623
The info doesnt show up all that shows up are '?' (question marks) and I dont have the option in ADVANCED to do that stuff, anyone know whats wrong???
Play Counter
Reply #624
I've recently installed the latest version of FOFR and everything seems to be working except the playcount feature. If I check the box like shown in the picture above will that cause my tags to get modified? I only want this to modify db records and not alter my tags.
Anyone have any ideas on how to troubleshoot this? I installed the playcount component that's linked at the very beginning of this thread. I'm running foobar v.0.9.4.1.
Sincerely,
FB
