Topic: Vorbis Listening Test (Read 78028 times) previous topic - next topic
Reply #125
So, what's the deal? Which codec should I use? It's not very clear from this theme. The freedom of choice is not, what I need. I wanna know, which codec showed best results. Is there such page ready? And is GTune 3 beta 2 + QKTune beta 3.2 EXPERIMENTAL going to be tested?
Based on the Vorbis listening test, aoTuV won at q 4, so at this nominal bitrate, it is expected to give you the best quality that the Vorbis codec has to offer.
The quality of the new aoTuV (beta 2) is not so definite.  Or perhaps I should say, not as definite as the previous aoTuV that was tested by at least 4 people.
Reply #126
With regards to the situation, I personally would love to see the new aoTuV be used in the multiformat test,  if it can be reliably verified that it performs better than the previous aoTuV we tested.  There is a risk that there is some regression and the last thing we want is for this to appear in the multiformat test.
However, on the other side of the coin, I did accept the point made by Roberto earlier that we shouldn't go about tuning Vorbis continually in order to improve its chances in the listening test up to the last minute.  That would be unfair.  Therefore I took the initiative and froze my version of QKTune beta 3.2 on that day and Nyaochi also did so for MTb2 the next day.  So I already departed from that rule slightly when I agreed to include the experimental version of aoTuV just before the test and I'm not sure if its proper that I bend the rule again after the Vorbis listening test had completed and we'd all agreed to that version of aoTuV.
Not to place the ball in his court deliberately, but it is ultimately for Roberto to decide whether he will accept this new version of aoTuV (if after preliminary testing, it gets the nod from listeners), to be included in his test or continue to use the one we agreed on in this thread.
Reply #127
If the older version of AoTuV is to be used, it should be made available on Aoyumi's page.  Right now, only the beta2 release is available.
ff123
Reply #128
ff123
I still have my own compile:
http://www.rarewares.org/quantumknot/oggenc-aotuv.exe
Hopefully it is bug free
Reply #129
If anyone has some spare time, by all means, do a test comparing this new aoTuV with the old one.  Irrelevant to whether it does or doesn't make it to the multiformat test, we would still like to know whether it is the best. I'm already contemplating using this to rip my audio collection
Reply #130
I won't accept anything without some valid backing up. Otherwise, I'll be making a criticism target out of myself. I only accepted featuring auTuV because there was a listening test behind it I could point critics to.
Reply #132
It seems that aoTuVb2 is superior to its previous version on the same samples.
It's probably a pretty safe bet that the other 4 people who listened to all 12 samples will also find beta2 to be better on this sample set (except maybe guru whose correlation with the group wasn't very high).
What is the bitrate penalty for this improvement?
ff123
Reply #133
Surprisingly, seems the b2 tends to produce smaller files.(at least with the 12 samples) Therefore, IMO including the b2 shouldn't be unfair to the 128kbps features tests.
Reply #134
Excellent. Thank you, harashin and ff123 (and of course Aoyumi).
Sorry if I looked overly paranoid, but I just wanted to remind everybody not to submit the latest and greatest version of a codec without testing. But then again, Roberto would never accept this anyway.
With all this progress on Ogg Vorbis, it's hard to believe that, only a few months ago, we had the infamous "Is Vorbis dead"-thread
Over thinking, over analyzing separates the body from the mind.
Reply #135
Well, if someone else can come with results that corroborate b2 is better than b1, I will include it in my test.
Anyone up to the challenge? I would need these results by monday the latest.
Edit: Thank-you for testing, harashin.
Reply #136
My listening result: aoTuV beta2 seems to be better than the previous version. Particularly, preecho problem in Blackwater and FloorEssence samples, background noise problem in MidnightVoyage sample and crash cymbal sound in thear1 sample are improved. IMHO, it's OK to use atb2 for 128kbps instead of at20040402 if someone else does not notice severe regression.
Here's the result.
Reply #137
is aoTuV beta2 available as oggenc yet?
Reply #139
thanx harashin
Reply #140
OK. Considering harashin's and nyaochi's results, I would reckon aoTuV b2 should be used instead of b1.
Everyone agree with me? Can we get things rolling?
Reply #141
I think so, yes.  Just gotta make sure that version of oggenc doesn't have the localisation difference with the decimal.  If so, I can provide a binary.
Reply #142
I think I will go with 4 anyway. So, no worries.
But, of course, a version with . or , hard coded would be welcome
Reply #143
Oh yeah, q 4. Silly me
Well, here is my hard coded version, for anyone interested.  It uses a . (dot)
http://www.rarewares.org/quantumknot/oggenc-aotuvb2.exe
Reply #144
Thank you for carrying out harashin, nyaochi, and a comparison test.
Locale fix oggenc (.version) of beta2 can be used from a test page.
This outputs the same data as a reference binary.
aoTuV test page
Moreover, on the page of aoTuV, oggenc and dll of the usual version (for win32) by offer of nyaochi are also prepared.
Reply #145
Now that we have some sort of scientific proof that aoTuV is the best Vorbis tuning out of the bunch, do you think it is time to make it the recommended encoder or do we need more rigorous testing before we retire GT3b2?
Reply #146
I think so. We, however, can recommend aoTuVb2 at -q4 and below at the moment.
Reply #147
So let's test aoTuV b2 at 180 kbps nominal bitrate (Q6), so we could compare it with Q5 of GTb2!
Reply #148
Comparing two codecs at such high bitrates is pretty difficult.
Reply #149
But in this specific case, it's maybe easier. I explain.
There are two known problems with vorbis at this bitrate. By "known", I mean generic problems, occuring with a lot of samples :
- noise issue (very small I admit after -q6): present with GT3b2, maybe removed with aoTuV
- pre-echo issues (very high with CVS code): excellent correction with GT3b (but maybe excessive bitrate inflation), aoTuV need to be tested.
By focusing the tests on these two problems (using percussive samples for pre-echo, and quiet samples for the noise problem), I suppose that we could build a serious opinion about respective quality of these two vorbis encoders.
I was far from internet these two weeks, and my latest aoTuV encoder was the prebeta2 release. I've played a bit with this one, mainly at 96-128 kbps. I've also encoded some  samples at -q6, and noticed sometimes additionnal noise, not very hard to ABX. IIRC [I don't have access now on my main computer], on one sample the noise was audible up to -q7. Obviously, the prebeta2 didn't solve the (or maybe "a") noise issue at high bitrate settings.
Testing is possible, and it's worth to try.
