Topic: Ogg Tagging (Read 6905 times) previous topic - next topic
Ogg Tagging
i think he dislikes it because everybody is used to ID3. But it seems that not very many people know that the ogg tagging system is much better! Just my opinion.
Ogg Tagging
With ID3v2, it's pretty obvious what you can add: If you, for example, want to tell anybody that this MP3 is encoded by you, you place your name in the "Encoded by" field. If you want to tell people how you encoded the MP3, you can use the comment field.
But with the OGG system, user A might do it like this:
ENCODED BY = User A
RIPPED WITH = EAC 0.9 PB 11
ENCODED WITH = LAME 3.90 Alpha8
OPTIONS = --r3mix
And user B might do it like this:
PROGRAMS = EAC / LAME 3.90
Everybody does his own thing, there's no "standard" way of inserting information, so if you get OGG files from different users, you'll find them all tagged in a different way.
Good idea to be able to add any information you want, but there should be more "pre-defined" fields like those that Winamp has for ID3v2.
I can understand why everybody hates ID3v2, though - it's just ridicolous, any program you come across supports different fields, some don't support ID3v2 at all...
BTW, while we're at it: Is it normal that Winamp only allows you to enter the names of the fields in caps?
Most people on the vorbis lists use scripts to handle the tagging
Do you mean scripts that can batch-tag already existing OGG files or scripts that tell the OGG encoder what values it is to use (based on parameters you can just write to the script)? The former would be great, that's exactly what I want...
CU
Dominic
Ogg Tagging
There are 'standard' fields, but they're not mandatory. The mailing list archive has a lot of info about the recommended tag format.
There exists an utility named vorbiscomment that can be used for general tag manipulation. Using that and some custom-tailored scripts lets you do pretty much whatever you want to do with it.
GCP
Ogg Tagging
offtopic, guyz !!!
If u want talk about tags, please start a *NEW* thread...
I want to talk about quality here, tnx.
Ogg Tagging
I like the fact that Ogg tags are user defined and non-standardized.
On the rare occasion that I do download a file from a P2P or a friend (I can't enjoy P2P-quality music anymore - thanks!), I will usually just wipe out the existing tags and put in my own.  Now I am empowered to implement my own tagging methodology for all my own files.
Ogg Tagging
GCP
Thanks Garf. Where can I access the mailing list archive?
I'll look for vorbiscomment, sounds good to me (I read about it on xiph.org, but didn't bother to download it).
CU
Dominic
Edit: Sure I found that archive, it's right on the Xiph website
Edit 2: Where the hell can I download vorbiscomment? I just can't find it...
Ogg Tagging
Try the Vorbis-tools package, if there is one.
GCP
Ogg Tagging
I simply can't find it (at least not a Windows compatible version), sorry!
Ogg Tagging
In that case, you might want to ask about it on the mailinglist.
I can't really help you here, as I don't use tagging myself.
GCP
Ogg Tagging
a lot !
