Topic: Kode54, come in please (Read 3669 times) previous topic - next topic
I dont know if you've received the letter from me.
so I post here
I have a copy of your SoundTouch plugin.
I wrote a general plugin, which is named "Repeat for foobar2000", just for training listenning(for example, learn a foreign language). Some friends help me can add some "rate adjusting" feather in that plugin, and I knew that you have realized it, so I downloaded your source code, and made a little change. In one word: I embeded your most source code into my plugin. It works well, thus my plugin is both a general and DSP plugin.
I've read your COPYING.TXT, so I wrote these to ask you if I can use your source code, and IF I can distribute my plugin ?
If it would be distributed, what shall I do? how to distribute it?
Best wishes
Good good study, day day up, :)
[span style=\'color:red\']The superman is the meaning of the earth.
Let your will say: the superman shall be the meaning of the earth![/span]
My component is LGPL whenever I feel like updating its headers and updating to the latest SoundTouch. Since you modified my source code, you must release it. Oh boy!
Roger!
I just updated it to SoundTouch v1.2.1, compiled with FLOAT_SAMPLES. Plus, even though I handle all likely error conditions outside of SoundTouch, I added exception handling blocks to watch for flying errors. Who knows?
errrr, I knew it
last night(local time) after you released it
and I patched the VC6.0 (to pack 5), and  support 32 bit sample now
thanks for your new source codes
though I knew nothing about sample or soundtouch, I can read the source code
just edit that #define
