Topic: foo_mixer does... nothing? (Read 4051 times) previous topic - next topic
[EDIT]: this problem is fixed now - take a look at this thread.
i downloaded No-Delay Volume Control 0.3 (foo_mixer),
set up hotkeys and menu entry, pressed those keys and so
on but nothing happens.
am i the only one experiencing this?
does anybody know what i am doing wrong?
ps: i run fb2k version 0.8b9 on win98se.
Well, it should "move" main slider in your system's volume control... At least it does for me.
i should have taken a look at the console earlier: "INFO (foo_mixer) : error".
would be cool if you can fix it!
@messer
have you got my e-mail?
J have same problem.
Win98SE, foobar 0.7.7a, two sound cards - SB128PCI(Ensoniq) and Crystal.
Foobar output set to SB128PCI(waveout).
in console see  "INFO (foo_mixer) : error", when attempt tune a volume.
version 0.41 should fix this issue: look HERE!
you'll need to move to foobar 0.8 to be able to use it.
Ok, in 0.8 all work correct. Thank!
