Topic: AAC @ 128kbps listening test discussion (Read 86249 times) previous topic - next topic
Reply #75
Well, I see there is too much discussion about what codecs to support and what anchor to use. I think the best and most fair way to settle the issues is creating a poll.
Do you agree?
Yes, absolutely.
I think this would be the best way to settle this issue.
But I think that everybody agrees on the 3 codecs you mention, so why don't you have a list with only the remaining codecs. Let every one vote and select the three with the most votes.
Reply #76
Two, actually
(The anchor would be handled in another poll)
I think that might work too, although that would limit votes to one per person, and the ideal would be two. Ideas, comments?
Reply #77
Hmm?
Two separate polls?
Monday through wednesday, choice of first contender.
Separate poll, thursday through saturday, remaining candidates minus first poll winner.
It's the only thing that comes to my mind right now.
Reply #78
that's a good idea, having a separate poll for the anchor i think it's the best choice right now
after reading this thread i've been convinced that LAME would not be a good anchor, now my vote would go for iTunes since it had the lowest score in the last test
Allegari nihil et allegatum non probare, paria sunt.
Reply #79
go for the polls separated by time.
please just pick an anchor. it doesn't really matter as long as it sucks. it isn't in there to compare to the other codecs, its there to lose, and keep the other ratings up.
Reply #80
My vote is to use the old FAAC as the anchor.  After all, this test is about AAC.
Reply #82
What about the Homeboy AAC encoder as an anchor? Wasn't it really bad?
Reply #83
Regarding Nero AAC - Fast mode shouldn't be used, as it is still not tuned.
Reply #84
Besides, what's wrong with using Lame in many tests? It allows (to an admittedly small amount) inter-test comparability (Another meaning of the word anchor?), while FhG l3enc 1.0 will only make the used rating range smaller.
I like the idea.
Using a stable high quality encoder as an anchor could indeed allow some inter-test comparison and IMO such kind of anchor would be much more valuable than any low quality old encoder. An ancient encoder is just a waste of listening slot.
Let's be realistic: If Lame is included, it won't be an anchor. It will just be another competitor. An MP3 competitor in an AAC test. You probably notice the mess here...
How can you know LAME won't lose? IMHO LAME at a last place is a realistic scenario.
I really think comparing the best MP3 to the worst AAC encoder would be fascinating and I can't see any mess here.
Reply #85
EDIT: Winamp problem is a decoder-only problem. Nothing seems wrong with the encoder.
EDIT: Hmm, actually I can't be sure if this is an encoder problem too. I guess some testing should be done whether a Winamp file decoded with Winamp sounds better then with another decoder. The difference between 2 decoded samples (winamp decoder versus another) is quite difficult to hear, but in a test like this it will probably be noticed.
Besides this, I think NCTU-AAC should be added to the test, just to show how much it sucks. As low anchor also the new Adobe Audition filter could be used.
Menno
Reply #86
If everyone knows that NCTU-AAC sucks badly may be it could be used as anchor? Just a thought.
-Eugene
The  greatest  programming  project of all took six days;  on the seventh  day  the  programmer  rested.  We've been trying to debug the !@#$%&* thing ever since. Moral: design before you implement.
Reply #87
How about VQF as anchor? According to AudioCodingWiki , it is(was?) a part of MPEG-4 Audio version 1.
Actually, TwinVQ is part of MPEG4 audio. It's slightly different from VQF, and in MPEG4 audio it's limited to veeeery low bitrates - around 8-16kbps
That said, I was planning to use it as an anchor in the multiformat test that will come after the AAC test.
VQF ran at around 80-96kbps. i should know, i was the one that was so happy about it intially (with my 128kbps mp3 vs 96kbps vqf) i spammed the mp3 newsgroups and mp3.d newsgroup about it when i first started playing with it. (i wouldn't even touch it now, altho i think it's in my audio tools collection somewhere X)
can't find it or anything else that's helpful .. seems to have fallen off google
oh, here we go.. here's one at least... http://www.mp3-tech.org/tests/pm/VQF-96k.htm
Reply #88
A question comes to mind: Is NCTU AAC bad enough to be used as low anchor?
Reply #89
But if, say, Lame finishes last in both the AAC test and the multiformat test (excluding anchors, the latter is to be expected), you will only provoke senseless claims like "Vorbis finished 1.2 points ahead of Lame in the multiformat test, but FAAC only managed an advantage of 0.9 in the AAC test, so Vorbis must be better than FAAC".
Well, such claim is better than pure guess when you can't compare faac to vorbis directly.
Reply #90
@ Menno: Thanks for bringing this issue to our attention.
Discussion here:
http://www.hydrogenaudio.org/forums/index....ndpost&p=182562
About anchors: I'm taking note of all your suggestions, and will later create a poll so that people can vote on what they prefer. Thank-you.
Reply #91
rjamorim: Are you going to use VBR streaming profile with Nero? I have done some encoding with it, and the average bitrate is too high for this "128kbps" test. VBR Internet profile produces closer to 128kbps on average.
I think that more encoders should be included or the anchor should be replaced with some AAC encoder. As i did the MP3 test, the anchor was useless to me, and this time it make out quite well against some other encoders.
Reply #92
Seconded. Same here.
Reply #93
I personally would prefer that fewer codecs be tested rather than more.  If an anchor is used it should sound bad, IMO.  Otherwise, I think it's better to just drop it.  Especially on a test in which all the codecs should approach transparency.  6 codecs was almost too much for me in the mp3 test.
ff123
Reply #94
Evil Psytel as anchor.
Reply #95
OK, now a fucker decided to mess my poll.
My patience is growing too thin, so I'll tell you what I plan to do:
-Compaact and Real are in
-Winamp is out because it seems to be broken, so it would be unfair to test it now.
-NCTU is in as an anchor.
-The test will be encrypted and will require Java ABC-HR.
Flames? Opinions? Comments?
BTW: Everything is discusseable, except encryption. It is definitely going to happen.
Regards;
Roberto.
Reply #96
It may sound a bit unfair to newer members, but to remove any doubts about manipulating the result in favour of compaact!, I suggest to only take hydrogenaudio members into account, that were members *before* the release of compaact!, i.e. end of october 03.
If the participation at the listening test would be without restriction, and compaact! would rate good, nobody would believe it now anyway.
Alexander
Reply #97
*deleted*
Reply #98
How strong this encryption is? What crypto system it uses?
Juha Laaksonheimo
Reply #99
Ph34r my m4d scr33ning skillz!
