Topic: HTML code bug? (Read 3056 times) previous topic - next topic
HTML code bug?
Links to individual components show up as
http://www.foobar2000.org/#foo_input_std
instead of
http://www.foobar2000.org/components.html#foo_input_std
Am I right?
Life is Real...
(But not in audio :) )
HTML code bug?
"Not here"
... Unless someone just fixed it.
HTML code bug?
"Not here"
Both Mozilla 1.6 & IE 6.0 give the same result as mentioned above, after shift+refreshing.
Strange
Life is Real...
HTML code bug?
instead of
Am I right?
Yes. You are right. Here
This appears to be the problem:
<base href="http://www.foobar2000.org" />
Should be:
<base href="http://www.foobar2000.org/components.html" />
I think.
HTML code bug?
Hmm, I guess Opera 7.50 build 3494 is ignoring that tag.
HTML code bug?
This explains it: Base
Netscape and Opera both ignore improperly terminated URLs used as the BASE HREF value. eg: relative URLs in a document that used "http://www.blooberry.com" as the HREF would resolve to "http://[relative URL]", and "http://www.blooberry.com/indexdot" would resolve to "http://www.blooberry.com/[relative URL]". To prevent this problem, use a trailing "/" character to properly terminate the URL. Internet Explorer, by the way, accepts both URL forms.
<base href="http://www.foobar2000.org" /> is the incorrect URL, but Opera ignores it becaude it is not written: <base href="http://www.foobar2000.org/[/b]" />
Interesting... I think!?
HTML code bug?
This is my fault.  I was using the base tag so that I could edit the file off the server and preview the changes without also having to download all the images and css and stuff.  I don't have access to the server atm, so hopefully someone else can just remove it.
HTML code bug?
Fixed, thank you!
Life is Real...
