Topic: Title bug? (Read 2880 times) previous topic - next topic
Title bug?
Well I've sat on this one for a fair amount of time but I think I should bring this to the attention of the crew...
Tune into:
http://www.puredj.com/etc/pls/128K.pls
If you tune into it with Winamp, the metadata title is correct and there is no artist. However in foobar2000 there is an artist field which contains the title value, and the title value contains the title minus the first 2 characters.
ie it shows up as: "abcdefghijklmnopqrstuvwxyz - cdefghijklmnopqrstuvwxyz" all over foobar2000 with default strings.
I wouldn't like to try and diagnose this although I have a fair idea of what may be causing the problem, I'm not 100% certain it is actually foobar's fault.
Shoutcast based server, by the way...
Alex
Title bug?
The correction should be included in the next release.
Title bug?
Wow... cheers!
Al
Title bug?
I've found 0.7.7c but there's still no change
Maybe it's not been included yet?
First time I've used the beta's.
Al
Title bug?
Al
kode54 was probably refering to next major release, not hotfix release.
