Hi, I recently fired up FB2K to play some tunes (duh) and was greeted with the following error message upon hitting play:Illegal operation:
Code: C0000094h, flags: 00000000h, address: 01D04DD7h
Call path:
playback_core_i::g_thread_func=>playback_core_i::thread_func=>output::update
Code bytes (01D04DD7h):
01D04D97h: 44 24 04 8B 43 20 89 74 24 0C 89 44 24 14 89 54
01D04DA7h: 24 10 E8 52 5D 01 00 EB BA 57 56 55 53 8B 6C 24
01D04DB7h: 14 8B 5C 24 1C 8B 4C 24 18 83 EC 3C 8B C5 C1 E0
01D04DC7h: 04 8B F0 0F AF F3 8D 3C 09 03 FF 03 FF 8B C6 99
01D04DD7h: F7 FF 89 44 24 08 DB 44 24 08 DC 1D 30 56 E1 01
01D04DE7h: DF E0 9E 76 78 89 4C 24 08 C1 E3 04 DB 44 24 08
01D04DF7h: DC 0D 38 56 E1 01 89 5C 24 08 DC 0D 40 56 E1 01
01D04E07h: DB 44 24 08 DE F9 DD 5C 24 20 8B 44 24 24 8B 4C
Stack (0108F6B8h):
0108F698h: 00 10 00 00 00 00 00 00 00 00 00 00 B0 02 00 00
0108F6A8h: 00 00 00 00 F4 03 BD 00 0B 04 00 00 02 00 00 00
0108F6B8h: 99 EF E7 77 FF FF FF FF 0C 00 00 00 84 C2 F5 77
0108F6C8h: 7C EF E7 77 FF FF FF FF 0C 00 00 00 E0 F6 08 01
0108F6D8h: 04 00 00 00 28 2E 17 00 00 00 00 00 60 61 DD 01
0108F6E8h: 4C 41 4D 45 61 63 6D 20 30 78 30 30 BC F8 08 01
0108F6F8h: D0 F7 08 01 00 02 00 00 55 00 00 00 CA 32 D0 01
0108F708h: 80 BB 00 00 00 00 00 00 02 00 00 00 EE F7 F5 00
0108F718h: BC F8 08 01 19 00 00 00 20 E5 D1 01 2F 98 F5 77
0108F728h: 08 06 15 00 00 00 A3 00 01 00 00 00 01 00 00 00
0108F738h: 74 F7 08 01 96 39 E7 77 9E 39 E7 77 00 00 D0 01
0108F748h: 90 01 00 00 E0 F4 B5 76 18 00 00 00 00 00 A3 00
0108F758h: 00 00 00 00 44 F7 08 01 00 00 00 00 DC F7 08 01
0108F768h: 88 F9 08 01 19 00 00 00 20 E5 D1 01 9E 39 E7 77
0108F778h: AC F4 08 01 DC F7 08 01 F0 19 D0 01 FF FF FF FF
0108F788h: E8 F7 08 01 3D E7 D1 01 00 00 D0 01 19 00 00 00
0108F798h: 18 00 00 00 20 E5 D1 01 00 00 15 00 0F 98 F5 77
0108F7A8h: 2F 98 F5 77 08 06 15 00 00 00 A3 00 01 00 00 00
0108F7B8h: 01 00 00 00 F8 F7 08 01 00 00 00 00 28 2E 17 00
0108F7C8h: 19 00 00 00 18 00 00 00 3C F8 08 01 E7 E5 D1 01
Registers:
EAX: 00177000, EBX: 00000002, ECX: 00000000, EDX: 00000000
ESI: 00177000, EDI: 00000000, EBP: 0000BB80, ESP: 0108F6B8
Crash location: "lameACM", loaded at 01D00000h - 01E34000h
Loaded modules:
foobar2000 loaded at 00400000h - 00440000h
ntdll loaded at 77F50000h - 77FF7000h
kernel32 loaded at 77E60000h - 77F46000h
USER32 loaded at 77D40000h - 77DCC000h
GDI32 loaded at 77C70000h - 77CB0000h
ADVAPI32 loaded at 77DD0000h - 77E5D000h
RPCRT4 loaded at 78000000h - 78086000h
COMCTL32 loaded at 71950000h - 71A34000h
msvcrt loaded at 77C10000h - 77C63000h
SHLWAPI loaded at 70A70000h - 70AD5000h
utf8api loaded at 10000000h - 1000B000h
comdlg32 loaded at 763B0000h - 763F5000h
SHELL32 loaded at 773D0000h - 77BC2000h
foo_albumlist loaded at 008B0000h - 008B9000h
foo_ape loaded at 008C0000h - 008DF000h
foo_cdda loaded at 008E0000h - 008EE000h
foo_console loaded at 00900000h - 00908000h
foo_diskwriter loaded at 00910000h - 0091B000h
foo_dsp_crossfade loaded at 00920000h - 00927000h
foo_dsp_extra loaded at 00930000h - 00945000h
foo_flac loaded at 00950000h - 00966000h
foo_id3v2 loaded at 00970000h - 00996000h
MSVCP60 loaded at 55900000h - 55961000h
foo_input_std loaded at 009A0000h - 00A2A000h
MSACM32 loaded at 77BE0000h - 77BF4000h
WINMM loaded at 76B40000h - 76B6C000h
foo_masstag loaded at 00AB0000h - 00ABE000h
foo_mod loaded at 00AC0000h - 00ACC000h
BASS loaded at 00AD0000h - 00B26000h
ole32 loaded at 771B0000h - 772D1000h
foo_output_std loaded at 00B30000h - 00B39000h
foo_out_dsound_ex loaded at 00B40000h - 00B49000h
DSOUND loaded at 51080000h - 510D6000h
VERSION loaded at 77C00000h - 77C07000h
foo_read_http loaded at 00B60000h - 00B6A000h
WS2_32 loaded at 71AB0000h - 71AC4000h
WS2HELP loaded at 71AA0000h - 71AA8000h
foo_rgscan loaded at 00B70000h - 00B7B000h
foo_spc loaded at 00B80000h - 00B92000h
foo_speex loaded at 00BA0000h - 00BB8000h
foo_ui_std loaded at 00BC0000h - 00BD8000h
foo_vis_manager loaded at 00BE0000h - 00BE8000h
foo_vis_test loaded at 00BF0000h - 00BF9000h
foo_wavpack loaded at 00C00000h - 00C0B000h
uxtheme loaded at 5AD70000h - 5ADA4000h
MSCTF loaded at 74720000h - 74764000h
TrayIt! loaded at 494E0000h - 494E7000h
ctagent loaded at 00E10000h - 00E20000h
wdmaud loaded at 72D20000h - 72D29000h
msacm32 loaded at 72D10000h - 72D18000h
midimap loaded at 77BD0000h - 77BD7000h
KsUser loaded at 5EF80000h - 5EF84000h
imaadp32 loaded at 58420000h - 58427000h
msadp32 loaded at 72CF0000h - 72CF6000h
msg711 loaded at 58330000h - 58335000h
msgsm32 loaded at 58300000h - 58308000h
tssoft32 loaded at 582D0000h - 582D4000h
tsd32 loaded at 73B70000h - 73B77000h
msg723 loaded at 58310000h - 5832D000h
msaud32 loaded at 58340000h - 5838D000h
sl_anet loaded at 582E0000h - 582FE000h
l3codeca loaded at 01360000h - 013EA000h
iac25_32 loaded at 01400000h - 01437000h
l3codecp loaded at 01850000h - 018EE000h
lameACM loaded at 01D00000h - 01E34000h
URL loaded at 71D90000h - 71DAD000h
imagehlp loaded at 76C90000h - 76CB2000h
DBGHELP loaded at 6D510000h - 6D58D000h
Version info:
foobar2000 v0.7.6
UNICODE
I tried doing a google search and searching the forums, but to no avail. It happens with 0.7.4 and 0.7.6. Any ideas? Winamp works fine if that helps at all.
