Topic: Controlling fb2k from external app (Read 4315 times) previous topic - next topic
I've done a little DLL wrapper that controls Winamp & Sonique remotely, and I would like to add foobar compatability also.  Could someone help me out with the window name for foobar ( e.g. FindWindow("Sonique Window Class", NULL); )?
That's pointless, since foobar2000 has no native Windows message API. You can use command line parameters instead. There is also a plugin called foo_remote that provides a Windows message API. IIRC there is/was a plugin that emulated the Winamp 2 API.
Erm, I was hoping for something a bit simpler than that.  I use TrueLaunchBar which has a foobar2000 plugin, which works without any "plugins" installed.
Any other ideas are appreciated.
DB
actually...  the truelaunch bar plugin does use a foobar component to work.  It's called "TLB Remote Control".
I don't know if it's compatible, but here is the source of a DC++ plugin (read .dll) to control wmp, winamp, foobar and other media players.
I ended up writing my own FB2K plugin which uses shared memory to command FB2K from external apps.
Wasnt too difficult to make at all.
I prefer to use my own than foo_remote.
