Topic: Some questions about WMA (Read 4745 times) previous topic - next topic
I would like to know the maximum bit rate allowed in WMA. I remembered somebody said it is 160kbps because "Microsoft claimed that WMA has the same quality as MP3 at half of its bit rate". However, my friend created some WMA files at 192kbps. So what is the maximum bit rate allowed in WMA?
Regards,
William
The max bitrate using the command line program (wm8eutil.exe) is 192 kbit/s.  Both 44.1 and 48 kHz sampling is supported.
ff123
I've heard that you can play 192kbps WMA  ONLY  at the computer which was used for encoding. Is it wrong ?
Or is it true only for some versions of WMA encoder ?
Only when the option "protect content" is turned on, i think (Windows Media Player - Extras - Options - copy music)...
