Topic: Who has the best replaygain calculations? (Read 2107 times) previous topic - next topic
It would be nice if replaygain calculations were similar for MPC,Vorbis and MP3. Sure, if you tweak MP3's globabl gain, the adjustment can't be so precise, but MPC and Vorbis replaygains should be similar. Obviously all use 89db as default.
I tested only few louder tracks with MPC and Vorbis replaygain (title gain), the difference wasn't very big, but audible: about 1dB. Vorbisgain reduced the loudness about 1dB more than MPC's replaygain.
MPC replaygain's source is here, don't know about vorbisgain source.
Hopefully the code which has the most accurate replaygain calculation would be used for all replaygain programs.
Juha Laaksonheimo
The latest VorbisGain source is included with the daily vorbis files (from RareWares). It uses the same replaygain code as MP3Gain (and as specified at replaygain.org), so that part can be found here
MPC replaygain uses slightly different code. It calculates the RMS over shorter blocks, 10 ms rather than 50 ms, and to compensate for that, it "averages" the value over time. This would explain the difference.
But that doesn't answer the question which is better. AFAIK there are cases the "standard" replaygain code doesn't handle quite right, but I don't know if the MPC version is any different. However, you can easily make the MPC replaygain behave the same as VorbisGain. Just remove the "#define KLEMM" row in gain_analysis.c and recompile. Or change the "#define" to "#undef".
