Topic: WV to DSF using wvunpack: No tags are present in the destination file. (Read 1962 times) previous topic - next topic
I tried this command => wvunpack --dsf -y ".\source.wv" ".\destination.dsf"
I checked the documentation (https://www.wavpack.com/wavpack_doc.html) and nothing jumps out in relation to wvunpack + tags.
suggestions/tips? thanks
EDIT: when I say no tags, I meant none at all are present in the destination including title, trackno, album, artist and etc.
Re: WV to DSF using wvunpack: No tags are present in the destination file.
If you want the tags from the .wv file, open both in say Mp3tag and copy over; wvunpack does not export tags from the .wv file.
The idea behind WavPack was to get you the source file back bit-identical; if there are tags in the wvunpacked file, it will be those which were there originally, not those of the .wv file.
Note:
When you force a different output format like with --dsf, it kills the non-audio chunks. From the manual, All extra information in the original file's header and trailer will be lost and a "fresh" DSF header will be generated.
Wvunpack cannot "convert DFF non-audio chunks to DSF non-audio chunks". (And if I am right, DFF does not really allow for tags either, although some hacks exist. Anyway, the same goes for WAVE to AIFF or the other way around.)
In the meantime, I used MP3Tag to copy/paste the tags. I was just hoping it can be done automatically. Thanks for the response
