Topic: Exact Audio Copy v1.7 [now v1.8] (Read 9588 times) previous topic - next topic
Exact Audio Copy v1.7 released
Homepage:
http://www.exactaudiocopy.de/
Download:
https://www.exactaudiocopy.de/en/index.php/resources/download/
Changelog July 13, 2024:
- Standard setup now using AccurateRip meta instead of gnudb.org for metadata retrieval
- AccurateRip meta does not yet support submissions, but will be in the future
- Updated the Musicbrainz Metadata plugin, for better CD information, more covers & lyrics
- Removed freedb integration completely (including genre selection, etc.)
- Updated flac and CTDB applications in the EAC setup
- Fixed and new command line parameters
- Fixed problem of using the wrong browser when opening a link
- Found a problem with communication with AcoustID via the plugin
Exact Audio Copy v1.8 released
Changelog July 14, 2024:
- There was a small problem with version 1.7 when using it as fresh install on a new computer. In that case, no email address was set and thus the metadata retrieval failed. Here comes version 1.8, which should fix this problem.
MOD edited
Re: Exact Audio Copy v1.7 [now v1.8]
Great!  3.5 years since 1.6, great to see!!  Thanks for the heads up!
korth
Because of some concerns regarding freedb/gnudb, I removed the freedb support completely, including freedb genre, etc.
What concerns were there?
Allegari nihil et allegatum non probare, paria sunt.
Hi.
I think I found a bug in this version.
When you press the "Eject" icon and leave the pointer above the icon, the CD will eject but it will maintain the CD dashboard details - it will not refresh - even if you place a new CD - as long as you keep the pointer over the icon. If you move off the pointer then it will refresh or go blank after the CD is ejected. If you press the icon and move the pointer off immediately, it will behave as the same as ejecting by the drive eject button.
Can anyone confirm whether this used to be this way in the last version or whether this is really new?
Not duplicating. Win 11 Pro, EAC v1.8
X
korth
Hi. I'm suspecting this happens with 1 hour long CDs. I'm going to make a GIF...
Right. I got it "reproduced" in this GIF. The resolution is crap, but it helps to see more or less what happens.
I also noticed that the reverse happens - when the disc is ejected and you press again, the command to load is the next command. If you load up with the icon and do not move the pointer out, the dashboard will remain blank until you move it off that icon.
Another unfixed Bugs:
I like to use the Flac format with embedded cue sheet for archiving CDs and was surprised that sometimes the Flac archive generation fails.
That's a bit mean. The RollingsStone CD producers like to use characters in the CD title that are not allowed in file names. In this particular case 06/24.
EAC also detects this and replaces the characters. But in the %CUESHEET% macro, the original CD title with the illegal character is returned as the file name, while EAC has created the CUE sheet with the corrected file names.
X
Another Bug:
I actually use the wave editor in EAC to generate CUE sheets automatically.
There is still the old bug that the complete file path is written into the sheet:
FILE "D:\Music\Beth_Gibbons_Live_11-05-24-BR2.wav" WAVE
TRACK 01 AUDIO
INDEX 01 00:00:00
TRACK 02 AUDIO
INDEX 01 04:04:32
TRACK 03 AUDIO
INDEX 01 09:18:38
TRACK 04 AUDIO
INDEX 01 12:58:50
TRACK 05 AUDIO
INDEX 01 18:30:30
TRACK 06 AUDIO
INDEX 01 23:10:18
TRACK 07 AUDIO
INDEX 01 26:43:15
TRACK 08 AUDIO
INDEX 01 30:49:01
TRACK 09 AUDIO
INDEX 01 34:44:00
I reported both bugs in early June, but got no response.
i wrote nonsens: EAC has no %CUESHEET%-Macro.
For this reason, I had created a file name for the CUE sheet from the macros "%albumartist% - %albumtitle%.cue" some years ago.
It would be nice if EAC had a macro for this.
Sorry for the noise.
Is it not possible to get proper pre-emphasis detection back in the software? IIRC it was removed years ago for some vague legal reasons however this isn’t something that appears to affect XLD, cueripper, etc. so AFAIK it should not be a current issue to reimplement within EAC?
@Peter
total bummer that they removed the freedb/gnudb search and submit feature
enjoyed, for many years, submitting old and new CD's to the freedb/gnudb
and v1.8 still has the submit button but it is greyed out and just stares at you
bring it back
also, today i inserted some cd from 1989 into EAC and chose accurate meta as the meta lookup and it didn't have the album listed
i guess it's time to submit it, but you can't? total bummer
it shows up from the musicbrainz search tho
not sure why freedb/gnudb was removed, all anyone needed to do was enter in a fake email and it would work...
