Topic: Fb2k Mobile App, Output Support Beyond 96kHz Resolution  (Read 976 times) previous topic - next topic
Currently both the Android and iOS versions of the app are limited to 96kHz output. When using any of these devices as a source player when connected to an external DAC this limit kicks in resampling that isn't necessary. It also means the same for Android-based DAPs.
Is there any way in the current version to enable this somehow to get a "bit perfect" transfer? And if not, is there a plan to do so in a future update?
This is not the same as the current "Resampler" DSP option which forces all files to that selected rate when applied. But that DSP effect is also capped at 96kHz. This too could be extended to 768kHz or beyond.
