Topic: Cutoff frequencies of lossy codecs (Read 5445 times) previous topic - next topic
Hello. Firstly, I want to say that I was wanted to open this topic in the "Lossy audio compression" category but I could not do that because opening a topic in there without selecting a sub category is not possible and this topic is not about a specific audio codec.
I started to see that most lossy encoders are starting to give higher and higher cutoff frequencies for a given bitrate (for example, FhG vs Lame). This may sound attractive, but a higher cutoff frequency means more black space in the frequency area and this sounds horrible to me. (An ABX is not needed per TOS because this is not about quality, this is about "sound color".) For example, a FhG MP3Enc lowest quality encoded 16kbps 11025Hz mono MP3 is pretty good for me, but a FhG Fastencc and especially Lame encoded 16kbps 11025Hz mono MP3 is not very good because of the higher cutoffs. The same thing applies for (for example) FhG MP3Enc encoded 64kbps 44100Hz mono and Lame encoded 64kbps 44100Hz mono. (I can't give an ABX because all of these files are totally untransparent to me. Of course, this does not mean they are all bad.) Of course, very low cutoff points are not good too, but I think the modern encoders are giving too higher cutoff points than the sweet spot. For example, I think 24kbps is the lowest bitrate that makes sense with 11025Hz cutoffless MP3's. Why those modern encoders are giving higher and higher cutoff points every day?
Re: Cutoff frequencies of lossy codecs
I don't mean to sound rude, but you have a strange idea of what constitutes 'sound color' and an even more strange sense of what constitutes 'good sound'! It must be clear by now that you are in a minority of one. Ultra low bitrate/samplerate does NOT generate anything that sounds good by any metric, certainly not in mp3.
I don't know much about low bitrate encoding.    I suspect the LAME developers don't care much about it.    From what I can tell, they are more interested in getting transparent, or near-transparent compression, possibly at the lowest bitrate that's possible.
Maybe because a lot of people judge quality by looking at the spectrum rather by listening?  Of course that's not what we do here.
With lossy compression some data must be thrown-away.   There are trade-offs.   If you force it to keep the highest frequencies something else will be thrown away, and what gets thrown-away may be more important than the high frequencies.    Once you are hearing compression artifacts different people may prefer different tradeoffs.    At higher quality settings, I assume the default LAME settings are optimized for most listeners and most program material    OGG or AAC may be able to do better, but I'm pretty sure LAME has been pushed as far as it can go.
Also at higher quality settings, it you hear an artifact it's usually not the loss of high frequencies you hear.   It's usually something else.    The highest audio frequencies (near 20kHz) are weak in normal program material so even if you can hear to 20kHz with loud test-tones in a hearing test, they are usually masked (drowned out) by not-as-high frequencies.     Eliminating "drowned out" sounds is the main way lossy compression gets-away with throwing-away data.
You are limited to half the sample rate (Nyquist) so at a sample rate of 11,025 the audio can't go above 5512Hz (even with lossless compression or no compression.)
Higher cutoff point also looks worse on the spectrum in most cases for me.
I'm still confused by what you're describing, but you should listen with your ears, not eyes.
@saratoga Looks like you didn't see the word "also". This means I already normally listen with my ears.
@DVDdoug I think OGG is doing worse. I prefer 22050Hz 32kbps FhG encoded MP3 over 22050Hz 32kbps Aotuv encoded OGG Vorbis, because it has richer spectrum as it has a narrower frequency range.
People generally says humans can hear up to 20kHz but I think nobody can hear above 18kHz and no adult can hear above 16kHz.
IIRC, some people have heard both 24 and 27 in trials, but at sound pressure levels you don't want to be exposed to for more than split seconds. That research was on how far up one should measure noise to protect against it, not on what you need to preserve.
@Klymins If you seek for quality, go lossless: 44.1KHz/32bfp if possible. Everything else is (almost) useless.
Hybrid Multimedia Production Suite will be a platform-indipendent open source suite for advanced audio/video contents production.
Official git: https://forart.it/HyMPS/
klymins is talking about samplerates of 11025 (layer III MPEG 2.5), 16000(?) and 22050, maybe 24000 (layer III MPEG 2)
So, no need to talk about human hearing limits or about methods to losslessly preserve the quality.
We also have to consider the technology limitation ( SFB 21, or SFB 12 on MPEG 2/2.5).
First hand tests with current codecs do not offer a "no-lowpass" option for these frequency ranges, so encoding a 11Khz track gets an almost 5Khz bandwith, rather than a  5.5Khz bandwith, even with the helix encoder.
Academically, it could be tested if not having a filter could be felt as better quality at the expense of slighly more artifacts.
Of course, in that case, the interest here in hydrogenaudio would be exclusively about sound quality, not "graph quality".
Modifying either LAME or Helix would be feasible for this test, but this is not a proposal, just a possibility.
SFB might not be as much a limiting factor here as opposed to 44Khz, since the frequency band is expected to have quite some power.
No need for ABX i believe you they sound a certain way, but you could have at least included some examples so we can contribute anything at all and to figure out what "sound color" you are talking about. If we encode this ourselves there is a high risk of confusion.
And so, with digital, computer was put into place, and all the IT that came with it.
What?
He means the almost always guaranteed huge emptiness in a spectrogram due to absolutely nothing anyone would listen to having high frequency data.
But it's kind of the reverse, the higher the cutoff, the less pure black. But that depends on your spectrogram's parameters. If you turn the sensitivity down all the blue/purple there would be black too.
It is the reverse of what he is saying.  Raising the cutoff means more frequencies get through, not less.
What?
A higher cutoff frequency means more black space below the cutoff frequency, and black spaces those below the cutoff frequency are much easier to detect than black spaces those above the cutoff frequency.
Do you mean "black spaces" the lowest amplitude range for the spectrogram (which its appearance depends on color scheme, the lowest amplitude range would be black, white, or any other color)?
Obviously, unless the difference between audio files either encoded using any lossy codecs or downconverted to lower samplerate/bitdepth and original WAV/FLAC files is so significant to the point it is even audible and doesn't require ABX to hear these differences, we shouldn't post spectrogram images (from any sources like foobar2000, Audacity, Spek, and even my own spectrum analyzer and spectrogram project) per ToS #8
Narrower frequency range gives richer spectrum? Errrrr. what?
Sorry, dude, but your takes on pretty much anything don't make any sense, and i've seen you spreading such kind of misinformation across multiple threads. What is your point?
Random digital audio nerd girl
I can only agree. All the similar comments suggest a pronounced hearing defect, not wishing to sound(!!) unkind.
It's your opinion, and that's my opinion. We must respect to different opinions. Please be more polite.
Everyone is entitled to their own opinion but there is no requirement that it should be respected. You continually profer statements and opinions that are completely contrary to the perceived wisdom on this and most other forums without any evidence that makes any kind of sense to the majority. Of course you are entitled to your opinion but please don't continue to try to convince others that your opinion is more valid than that of the majority.
I'm not trying to convince others, thank you.
Well, you constantly try to promote settings as "good" that make my toe-nails curl up. My humble opinion
