Topic: help setting up Georgia-ReBORN please  (Read 812 times) previous topic - next topic
i installed foobar2000 32bit and added latest Georgia Reborn v3.0-RC2 - Second Release Candidate
when it changes track just colours no pictures
how do i get tracks to play and the time they last for
many thanks in advance
Re: help setting up Georgia-ReBORN please
Hi @telboy1812,
you need to have cover.jpg/png or folder.jpg/png or front.jpg/png in your music album's root directory
or you need to have the album covers embedded into your music files.
-TT
ok TT so I need to make a folder and save some images to it
It is displayed in the Playlist Manager at the top bar of the Playlist, see screenshot.
Just mouse hover over the top bar of the playlist and it will show.
On foobar startup when nothing is playing, it will automatically show the total length of all tracks,
if you select multiple tracks it will calculate these lengths, and if you select all tracks CTRL + A
it will display again the total length.
-TT
Did you see the screenshot?
I've told you it is in the playlist top bar when you mouse hover it.
If you do not like the auto-hide feature, you can disable it in:
top Menu > Options >  Playlist > Playlist manager > Auto-hide.
-TT
i undid auto hide and got nothing like your screenshot sorry
Are you using style Alternative or Alternative 2 in top menu Options > Style?
There is actually an issue in version RC2 when using both of these styles in the
text button in the playlist top bar when turning off the auto-hide feature.
Please install the latest DEV version from here:
https://github.com/TT-ReBORN/Georgia-ReBORN/archive/refs/heads/master.zip
This version has fixed the issue with the "Alternative" or "Alternative 2" styles and you can
turn off again the auto-hide feature ( top Menu > Options >  Playlist > Playlist manager > Auto-hide ).
But still, the RC2 version works with the auto-hide feature enabled. Are you not using a mouse!?
-TT
your going to hate me i installed new restarted foobar and gas the same playlist manager nothing like the one in your screenshot
i use a trackball mouse
It is not in the playlist manager popup window, but it is in the playlist top bar like shown with the red rectangle in the screenshots...
Go to the playlist ( no top menu button active, if you have a panel button active, i.e Details, Library, Biography, click on it again )
then Shift + right click on a track row for advanced playlist context menu > Panel properties... ( at the bottom ).
Click on the "Export button" and save props.json file and then click on the "Clear button" and OK.
Now the player is using factory settings; you should see text in the playlist top bar if you move your mouse to the red rectangle
area like shown in the screenshots. With default factory settings, the auto-hide feature is enabled, you can disable auto-hide in
Please attach your saved props.json file here.
-TT
here is what my nephew did .......... i am off to bed early shift tomorrow but when I get home will delete all start a fresh once again thank you for your time and help
You do not follow my instructions...
Look at the attached video, this is how it should look when you start foobar and you have some albums in the playlist.
The player will display the Playlist panel on startup, no top menu panel buttons are active.
Then you just move the mouse to the Playlist top bar like in the video.
As you see, the text hides when the mouse leaves the top bar, this is the playlist manager text button auto-hide feature.
You can also disable the auto-hide feature as shown in the video. There is nothing more to it, it is just that simple.
If nothing is selected ( i.e on foobar startup ) it will show the total track length of the entire playlist,
if you select few tracks it will calculate the selected tracks total length and if you select all ( CTRL + A )
it will show again the total tracks length.
P.S If one of the top menu panel buttons are active ( Details, Library, Biography, Lyrics ),
you click on the active button again to return to the Playlist panel. These panel buttons can be toggled.
-TT
just before I go
So did you read the text I have sent you as private message and did you read the text from this reply here?
https://hydrogenaud.io/index.php/topic,125957.msg1044764.html#msg1044764
Have you watched the attached video from the replay?
It shows you exactly how to move the mouse to the playlist top bar which will display the playlist manager text,
further more it will also show you how to deactivate the auto-hide feature.
-TT
