Topic: 10 Audio Samples for Listening Tests (Read 1106 times) previous topic - next topic
Here are 10 audio samples for listening tests!  ;D
1. English male speech
From: Feed in Microsoft TTS: "Hello, world! This is my new audio file with speech! Try this and let you know your results!" using the Christopher voice
2. English female speech
From: Feed in Microsoft TTS: "Text to speech is good! Listen to this, it is good or bad?" using the Aria voice
3. Chinese male speech
From: Feed in Microsoft TTS: "您知道可以生成文本转语音文件吗? 让你知道你的想法!" using the Yunxi voice which it's translated with Google Translate from this: "Did you know that you can generate text-to-speech files? Let you know your thoughts!"
4. Chinese female speech
From: Feed in Microsoft TTS: "请注意,该论坛上链接的大多数软件可能可以安全使用。 如果您不确定,请随时在相关主题中询问,或发送私人消息给管理员或版主。 为了帮助遏制误报问题,或者如果您确实发现了实际的恶意软件,您可以通过此处链接的文章做出贡献。" using the Xiaoxiao voice which it's translated with Google Translate from this: "Please note that most of the software linked on this forum is likely to be safe to use. If you are unsure, feel free to ask in the relevant topics, or send a private message to an administrator or moderator. To help curb the problems of false positives, or in the event that you do find actual malware, you can contribute through the article linked here."
5, 6, 7 and 8. 4 fills
From: Very very very short segments of audio, slowed to ~5 seconds, blurred, normalized and faded in. All in FL Studio Edison
9. Happy strummed chord progression
From: "C - bIII V7 I.mid". Strumming was done in FL Studio
10. Sad strummed chord progression
From: "A - VI VIm i VII.mid". Strumming was done in FL Studio
All are under 30 seconds, to fit within the limits.
All attached, as 44.1 kHz, 16-bit WAV. FLAC in a separate post.
Re: 10 Audio Samples for Listening Tests
Here are the FLAC versions of the above files:
And here are the FSLAC versions of the files above, if you want something smaller than FLAC and even smaller than WAV:
