Topic: the seekbar is working wrong (Read 914 times) previous topic - next topic
the seekbar is working wrong. it move forward on approximately  1 mm, than go back approximately  2mm, And it repeats such actions
Re: the seekbar is working wrong
may be, I think problem is with foo_out_wasapis
foo_asap
foo_audiomd5
foo_cuesheet_creator
foo_deaf
foo_dsd_converter
foo_dsd_processor
foo_dsp_utility
foo_input_dvda
foo_input_ffmpeg
foo_input_sacd
foo_input_tta
foo_openlyrics
foo_openmpt54
foo_out_asio
foo_out_wasapis
foo_playcount
foo_renamer
foo_skip
foo_sqlite
foo_uie_albumlist
foo_uie_sql_tree
foo_vis_spectrum_analyzer
Thanks for the problem report. The foo_out_wasapis component reported latency incorrectly when Windows mixer and played material had different sample rates, When the ratio difference was big the seekbar was in entirely wrong position, easily visible with Waveform Minibar. Improved version uploaded.
There is still sometimes a tiny twitch backwards visible after seek, that is related to the fade handling. I hope you aren't too bothered by that.
