Topic: f2k 2.2 preview 2024-03-14 & 2024-03-18 WASAPI (shared) output problem @ 24/96 (Read 761 times) previous topic - next topic
f2k 2.2 preview 2024-03-14 & 2024-03-18 playback is choppy when using WASAPI (shared) to playback HiRez FLAC (24bit/96kHz)
Checked on clean install.
In f2k 2.2 preview 2024-03-08 WASAPI (shared) works fine.
Re: f2k 2.2 preview 2024-03-14 & 2024-03-18 WASAPI (shared) output problem @ 24/96
I can't duplicate it on mine. Current preview 2024-03-18, WASAPI shared and 24bit/96kHz FLAC. I also tried 88kHz. What is your DAC/audio device? Are you using any DSPs?
Think millionaire, but with cannons.
Thanks for the problem report, @pablak. I didn't consider to test high output sampling rates when I was testing if the new output changes affect any of my components. I'll try to get it fixed soon.
As a workaround you can enable the smooth fading option. Or try the built-in Default outputs, they use shared mode WASAPI too nowadays. Just in a different way.
Edit: Fixed in the just released version 0.6.22.
After update works fine.
Thanks for quick fix.
