Topic: ffmpeg decoder usage (Read 1546 times) previous topic - next topic
I believe I've correctly configured ffmpeg decoder to work on AIFF files.  However, I have no clue how to actually make it work.
I'm under the impression I can use it to decompress an AIFF file and return it to WAV format.  Is that correct?  If so, how does one go about doing it?
Re: ffmpeg decoder usage
aiff decoding is included in CUETools 2.2.5 and does not need to be added
(I mentioned in https://hydrogenaud.io/index.php?msg=1039574)
but the included decoder requires the ffmpeg.dll plugin which requires additional files to be downloaded.
(I mentioned adding required dll files for the plugin in https://hydrogenaud.io/index.php?msg=1039576)
Or you can get them from the download page http://cue.tools/wiki/CUETools_Download#FFmpeg_plugin_dependencies
korth
Yes, I have the dll files.  I downloaded when I initially downloaded CueTools.  The problem is I don't know what to do with those files (I put them in the plugins x64 folder).  I only downloaded CueTools last week so am a real novice in using it.
Given I have the dll files, I'm assuming there is no need for ffmpeg decoder.  Should I delete all mention of it in the CueTools?  If so, what's the nuts & bolts of using the decoder?
Make sure the ffmpeg.dll decoder is selected on the Formats tab. CUETools is expecting files that have the .aiff extension.
To convert .aiff to .wav
Action: Encode
Audio Output: Lossless
Audio File Format: wav
If you added the ffmpeg.exe decoder yes you can remove it by selecting it on the Decoders tab and pressing Delete on the keyboard or clicking the "-" button on the tab.
korth
Okay, I see one problem.  I don't have the ffmpeg.dll file.  I only have the .exe file.   Is the dll available under CueTools or should I find it under the site that I downloaded the ffmpeg.exe file?
ffmpeg.dll is built-in (included)
It is located at \plugins\CUETools.Codecs.ffmpegdll.dll
korth
Okay, but it doesn't show up as a option under the AIFF format drop down. I must have goofed something up.
Update - I forgot to update the decoder name when I replaced. the exe file with the dll (I used the entire name CUETools.Codecs.ffmpegdll.dll) in the decoder settings menu. So now it shows up under the formats menu.
Assuming it works, what's the next step to running it?
Edit: See Reply#3 "To convert .aiff to .wav" (I don't know what Input method you're using)
korth
Sorry, I missed the actions to take on your reply #3.  So I'm using the multi-select input option.  I have a folder with 12 Aiff files in it.
 I select that the item that says 12 files and run the options you suggested.  I get the message - CUETools.Codecs.ffmpegdll.dll: The system cannot find the file specified.
I continue to play with it am now getting "CUETools.Codecs.ffmpegdll.dll: The specified executable is not a valid application for this OS platform"  Strange as I didn't change anything except put the full path in the decoder settings menu.  Maybe this won't run on my old laptop running Windows 8?
Assuming you "unzipped" the entire archive, did you make sure all zip files were "unblocked"?
Known Issues When Unpacking the Archive
You left CUETools.Codecs.ffmpegdll.dll in its original location?
There is no need to setup a decoder for aiff as it is already built-in
korth
It appears most all of the files are blocked.  I'll unblock and try again.
Okay, unblocking all the files fixed the issues.  Thanks so much for your help.  I would never have thought to look to see if they were blocked.
