Topic: Rip with EAC, convert .wav to ALAC, using fre:ac (Read 2234 times) previous topic - next topic - Topic derived from Exact Audio Copy v1.6
downloaded & seems to be working well but i'm tryingto convert the .wav to ALAC, by dragging the .cue into fre:ac, and i get an error "unable to open file : "<album>".cue  ( how do i upload the screenshot )
Mod Edit: Removed quote
Re: Rip with EAC, convert .wav to ALAC, using fre:ac
i'm tryingto convert the .wav to ALAC, using fre:ac
Why not rip to ALAC in Exact Audio Copy?
using refalac https://wiki.hydrogenaud.io/index.php?title=EAC_and_QAAC
or
https://wiki.hydrogenaud.io/index.php?title=EAC_and_ALAC
Use the REPLY button to open the full editor.
X
Drag & Drop or select your screenshot file.
korth
hi,
here is the screenshot
Is this  a 'Tracks' rip (one-track-per-file)?
Spoiler (click to show/hide)
Could you post the text from the .cue file? (or attach file?)
Note: EAC will create a noncompliant CUE file to preserve the INDEX 00 (gap) information when each track is ripped to a separate file. fre:ac may not support noncompliant CUE files.
Note 2: fre:ac only supports .cue files encoded UTF-8 with BOM or ISO-8859-1.
korth
yes, you are right !
strangely, i can move the .cue from Easy Audio Copy, CUERipper & dBpower to fre:ac & they all work
is there a setting on Exact Audio copy or fre:ac, which i can change to support this ?
thanks, most appreciated
Could you post the text from the .cue file? (or attach the file?)
or
ive downloaded he ffmpeg-6.0.tar, unzipped to the EAC folder but cant seem tp find the ffmpeg.exe
As for the .cue file above (I created dummy files)
you can drop into CUETools and 'Correct filenames' (I have 'Overwrite' enabled)
This will change encoding from UTF-8 to UTF-8 with BOM
and remove the 'path' leaving only the filenames (fre:ac isn't finding the files)
modified .cue file attached
korth
many .. many thanks ...
ive got the alac working on Exact audio Copy
Note: the original .cue file created by EAC will load into fre:ac if the .cue file is located outside the 'path' used inside the .cue
FILE "VA - Rock 'n' Roll - 2009 - Original Hits - Rock 'n' Roll CD 6\01 - Track01 - Unknown Artist.wav" WAVE
korth
[attach width=700]26639[/attach]
hi,
many thanks
i got that right too ...
the alac in ExactAC, is weoking fab but i forget to make the .cue ... ( too used to EasyAc & CUERipper .) so also used the ffmpeg on the CUERipper & happy with rips
many thanks again
