Topic: LA NOIRE 64-bit Columns UI theme (Read 10311 times) previous topic - next topic - Topic derived from Columns UI appearance
Re: LA NOIRE 64-bit Columns UI theme
I'm checking the correct installation of the Theme. The bottom part of the buttons seems out of place to me...
How do I stop the disc from spinning? Because the buttons do not work.
I did not thing about stopping the spinning ...
Maybe create a button while do the job
Thank you for sharing this 64-bit theme.  I just installed it, and I got it working.
One tip that will resolve an issue others may run into:
Copy all files and replace what exists under your installed %APPDATA%\foobar2000-v2 (for non-portable install that is what I did).  Replace all existing content.  After you do this, go to options, Media LIbrary, and remove all paths from that config you copied and replace with your correct media library path.  This was a brand new install, so I faced no issues doing this.  There may be ways of keeping your existing library, but that is beyond my knowledge.
I did attempt to preserve my existing library, but I got JavaScript errors from not copying stuff I was supposed to.  I force copied everything on the second try to see success.
Again, thank you for sharing this theme.  This is the only shared theme for 64-bit fb2k I have found to date.
There are two issues that I currently face using this theme.  I am posting here for consideration of future improvements.
#1 The playlist view really needs a scrollbar to be able to scroll through many playlists.  When the small playlist window gets full, you cannot tell that excess content is not present.  In order to access all of my playlist, I had to change the sort from A-Z to Z-A.  This was when I realized that a scroll bar is not present and functional for the playlist window
#2 An easy way to see and change the rating for the currently playing must would be fabulous.
I don't use this theme but the playlist view and built in playlist manager have scrollbars. :/
The rating column in the playlist is clickable. It will use Playback Statistics (foo_playcount) if present. If not, will write RATING tags in your files.
More notes on playlist features:
https://jscript-panel.github.io/gallery/jsplaylist/#clickable-ratings
you are right. i'am actually making a big update of this skin . time time is missing me .... i hope soon almost finish . testing phase....
