Topic: Mp3tag 3.21a (Beta) (Read 1840 times) previous topic - next topic
Mp3tag 3.21a (Beta)
Mp3tag is a powerful and easy-to-use universal Tag Editor that allows to edit metadata of common audio formats where it supports ID3v1, ID3v2.3, ID3v2.4, iTunes MP4, WMA, Vorbis Comments and APE Tags.
3.21a (2023-07-16)
NEW: added JSON-related function json_foreach_reverse to web sources framework, which is to be used with json_foreach_end.
CHG: copying and pasting individual fields via the extended tags dialog now replaces existing values.
FIX: end editing in file list if window is resized.
FIX: option to prefer values from tag was shown also when configuring Custom List Values for _DIRECTORY.
FIX: option to only show user-defined genres was shown also when configuring Custom List Values for other fields than GENRE in some cases.
FIX: Custom List Values for directory field were duplicated on file selection change.
https://community.mp3tag.de/t/mp3tag-development-build-status/455
EZ CD Audio Converter
Re: Mp3tag 3.21a (Beta)
3.21b (2023-07-19)
NEW: added function SayDuration to web sources framework.
NEW: added scripting function fmtDuration to create a formatted duration string based on numerical input.
NEW: added JSON-related function json_select_many_count to web sources framework.
NEW: extended JSON-related function json_select_many of web sources framework with optional parameters for last item separator and maximum items to select.
NEW: added JSON-related function json_foreach_counter to web sources framework.
FIX: web sources framework IfGreater and IfLess did not perform numeric comparison in all cases.
FIX: edit field shown when adjusting metadata from Tag Sources was misaligned in some cases.
3.21h (2023-08-14)
NEW: LRC files are now also renamed, moved, and copied with corresponding MP3 and FLAC files.
NEW: added support for audio MD5 via %_md5audio% for WavPack.
NEW: added support for editing Tag Sources configurations via the Tag Sources menu.
NEW: added new key [MinAppVersionWin]=3.21h to require a minimum version of Mp3tag for a Tag Source to be used.
NEW: added functions IfVar and IfNotVar to web sources framework to check configuration settings from Tag Sources.
NEW: added new key [Settings]=Tag Source Configuration.settings to provide a settings schema for Tag Sources.
