Topic: FLAC streaming with Hi Fidelity not compatible with fb2j (Read 890 times) previous topic - next topic
I was upgraded Icecast server to kH17 versión and My Ogg flac stream  is unreacheable. Can't play with fb2K versión 2
I return to Icecast server kH15 and the links works again.
What is wrong?  VLC player works perfect.
About My radio La SuperSonica stream:
https://www.hiresaudio.online/la-supersonica/
Direct link:
http://c11.radioboss.fm:8093/stream
Icecast ssrver kH18 to kH21 versions has some Bugs but
kH17 versión is working fine with ant known Bugs.
Maybe You need to upgrade to latest Ogg Flac decoding libraries.
Re: FLAC streaming with Hi Fidelity not compatible with fb2j
Thanks for reporting.
This server is sending malformed FLAC headers in Ogg container.
Apparently they're accepted by reference Ogg FLAC reader, but not by mine.
Specifically, FLAC__stream_decoder_process_until_end_of_metadata() fails and my reader gives up after that.
I worked around this for the next update, but it's apparently a problem with the server. If you want existing foobar2000 versions to work, please downgrade server or report this as a bug to authors of the server software.
Thanks! I will check this issue with the server administratrators.
