Topic: Loudness Peakmeter  (Read 6861 times) previous topic - next topic
Re: Loudness Peakmeter
Version 0.2.0.0
Change Log
- Default UI theme color integration
- 64 Bit Version
- corrected handling of very high peaks (> 3dB)
- added local menu item for single spectrum view (columns UI + default UI)
Discussion and Support: https://hydrogenaud.io/index.php/topic,123954.0.html
MOD Edit: add 'Discussion and Support' link
Release 0.2.1.0 (x86 + x64)
Change Log
- FIX: drawing db scale above 0 dB does not exceed the limits of the client window.
- CHANGE: to keep it simple only the first two channels are displayed.
- IMPROVEMENT: Default UI color integration
Version 0.3.0.0 released
Change Log
- NEW: right shade in diagram area is now deactivated by default
- NEW: the transparancy of the right and left shade can be adjusted in the options dialog
- NEW: the font color of the loudnessmeter labels can now be adjusted in the options dialog
Alternatively, you can download the component as an fb2k component.
Version 1.0.0.0
- FIX: Reset of Internal channel count detection sometimes fails
- FIX: changed the labelling of the X and Y axis in the config dialog
- IMPROVEMENT: Better performance when processing 5.1 and 7.1 audio streams
- IMPROVEMENT: Export and Import settings by file
- IMPROVEMENT: Default settings have been changed for a better integration.
- IMPROVEMENT: better scaling of loudnessmeter for small sizes
- IMPROVEMENT: Mono/stereo only selection for the loudness measurement
