Topic: Flac 1.02 BeOS (Read 1492 times) previous topic - next topic
Flac 1.02 BeOS
Start. I'm using flac 1.02 for the BeOS architecture. This is going well. From packet data +50% data that can be pressed. But the exact number that I got from Lossless Comparison was around 52%.
Re: Flac 1.02 BeOS
There is no exact number in compression. If you make a zip file containing a text document, compression will be much more than when you make a zip containing a JPEG picture.
Likewise, if you make a FLAC containing only silence, the compression will be much greater than when you make a FLAC containing music. If you make a FLAC containing pure noise, you won't get any compression at all.
The 52% mentioned there is an average on a certain corpus of music, and is only useful for comparing with other codecs on the same corpus. There is no absolute there.
Re: Flac 1.02 BeOS
I respond in this regard. flac as a lossless file. contain data (single file) , flac.
